这段代码 我找到时 说明是可以将AutoCAD中的属性块中的属性提取到Excel中 我用的是AUTOCAD2007 打开VBA复制进去 然后工具-引用,把Microsoft Excel勾选上 然后编译 光标停留在“mspace As Object”这句上 编译报错 “成员已经存在于本对象模块派生出的对象模块中” 然后小弟查了很久 也不知道 对不对 把mspace改成了myspace 再编译就没有报错 通过了 但是运行宏的时候 又报错“运行时错误429,ActiveX部件不能创建对象” 请各位帮忙看一下 或者 高手可以指点一下小弟 感激万分 Public acad As Object Public mspace As Object Public excel As Object Public AcadRunning As Integer Public excelSheet As Object Sub Extract() Dim sheet As Object Dim shapes As Object Dim elem As Object Dim excel As Object Dim Max As Integer Dim Min As Integer Dim NoOfIndices As Integer Dim excelSheet As Object Dim RowNum As Integer Dim Array1 As Variant, Array2 As Variant Dim Count As Integer
Set excel = GetObject(, "Excel.Application") Set excelSheet = excel.Worksheets("sheet1") Dim Sh As Object, rngStart As Range If TypeName(ActiveSheet) <> "Worksheet" Then Exit Sub Set Sh1 = ExcelSheet1 Set rngStart = Sh1.Range("A1") With rngStart.Rows(1) End With Set acad = Nothing On Error Resume Next Set acad = GetObject(, "AutoCAD.Application") If Err <> 0 Then Set acad = CreateObject("AutoCAD.Application") MsgBox "请打开 AutoCAD 图形文件!" Exit Sub End If Set doc = acad.ActiveDocument Set mspace = doc.ModelSpace RowNum = 1 Dim Header As Boolean Header = False For Each elem In mspace With elem If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then If .HasAttributes Then Array1 = .GetAttributes Array2 = .GetConstantAttributes For Count = LBound(Array1) To UBound(Array1) If Header = False Then If StrComp(Array1(Count).EntityName, "AcDbAttribute", 1) = 0 Then excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TagString End If End If Next Count For Count = LBound(Array2) To UBound(Array2) If Header = False Then If StrComp(Array2(Count).EntityName, "AcDbAttributeDefinition", 1) = 0 Then excelSheet.Cells(RowNum, UBound(Array1) + 1 + Count + 1).Value = Array2(Count).TagString End If End If Next Count RowNum = RowNum + 1 For Count = LBound(Array1) To UBound(Array1) excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TextString Next Count For Count = LBound(Array2) To UBound(Array2) excelSheet.Cells(RowNum, UBound(Array1) + 1 + Count + 1).Value = Array2(Count).TextString Next Count Header = True End If End If End With Next elem NumberOfAttributes = RowNum - 1 If NumberOfAttributes > 0 Then Worksheets("属性取出").Range("A1").Sort _ key1:=Worksheets("属性取出").Columns("A"), _ Header:=xlGuess Else MsgBox "无法提出图形文件中的属性或此图形文件中无任何属性!" End If Set currentcell = Range("A2") Do While Not IsEmpty(currentcell) Set nextCell = currentcell.Offset(1, 0) If nextCell.Value = currentcell.Value Then Set TCell = currentcell.Offset(1, 3) TCell.Value = TCell.Value + 1 currentcell.EntireRow.Delete End If Set currentcell = nextCell Loop Set acad = Nothing End Sub |
