实体线型如果是BYLAYER的无法用(6 . "CENTER2")得到。最好分开写。 (DEFUN C:TEST () (SETVAR "CMDECHO" 0) (IF (SETQ SS (SSGET "X" '((8 . "0")))) (COMMAND "CHPROP" SS"" "LA" "01_CENTER" "C" "BYLAYER""LT""BYLAYER" "") ) (IF (SETQ SS (SSGET "X" '((6 . "CENTER2")))) (COMMAND "CHPROP" SS"" "LA" "01_CENTER" "C" "BYLAYER""LT""BYLAYER" "") )
…… (SETVAR "CMDECHO" 1) (PRINC) ) |
