查看: 1746|回复: 2
如何修改块的属性
发表于 2007-6-21 12:08:00 | 显示全部楼层 |阅读模式
在程序中自定义属性块后,如何获取并修改块的属性值呢?
不是块参照
谢谢
发表于 2007-6-21 12:39:00 | 显示全部楼层
Sub Example_Blockttribute()
    ' This example creates an MLeader object and gets and sets values for
    ' the block attribute type.
    Dim points(0 To 5) As Double
    points(0) = 0: points(1) = 4: points(2) = 0
    points(3) = 1.5: points(4) = 5: points(5) = 0
    Dim i As Long
    Dim oML As AcadMLeader
    Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
    oML.ContentType = acBlockContent
    oML.ContentBlockType = acBlockBox
    Dim sBlock As String
    sBlock = oML.ContentBlockName
    Dim o As AcadEntity
    For Each o In ThisDrawing.Blocks(sBlock)
        If o.ObjectName = "AcDbAttributeDefinition" Then
            Call oML.SetBlockAttributeValue(o.ObjectID, "123")
            MsgBox oML.GetBlockAttributeValue(o.ObjectID)
        End If
    Next o
    Update
    ZoomExtents
End Sub
 楼主| 发表于 2007-6-22 16:01:00 | 显示全部楼层
能不能给个简单的例子,我是在CAD2004下的。
上面的例子看不懂。
GMT+8, 2025-5-1 23:01 , Processed in 0.183205 second(s), 23 queries , Gzip On.
