就是在点选全部选项时,所有的都选择了,但我现在要再选一次全部,把全部选项按钮换成空的,但其它的三个怎么也变成初始状态? 再如,我再增加一个按钮如选前面二项的,要求,在选中全部选项后,再点这个增加的按钮,.就只会选前面二项,全部按钮和第三项按钮都变成空的初始状态? 这下面是我写的一部份,麻烦DX帮忙修改下,多谢 (setq dcl_id(load_dialog "F:\\s04.dcl")) (new_dialog "s04" dcl_id) (action_tile "YY" "(tt)") (action_tile "accpet" "(sss)(done_dialog)") (start_dialog)(unload_dialog dcl_id) (defun sss()(setq t1 (ATOI (GET_TILE "XX")) t2 (ATOI (GET_TILE "XY")) t3 (ATOI (GET_TILE "YX")) t4 (ATOI (GET_TILE "YY")))) (defun tt()(set_tile "XX" "1") (set_tile "XY" "1") (set_tile "YX" "1"))
