看看这个能用否,好像来自本坛 (DEFUN c:tmp (/ ENT1 ENT2 N PT PTS SSG FILE) (vl-load-com) (SETQ ent1 (VLAX-ENAME->vla-OBJECT (CAR (ENTSEL "\n选取一根线:")))) (PRINC "\n选取一组竖向坐标线:") (SETQ ssg (SSGET '((0 . "LINE")))) ;;获取交点集 (SETQ pts nil) (REPEAT (SETQ n (SSLENGTH ssg)) (SETQ ent2 (VLAX-ENAME->vla-OBJECT (SSNAME ssg (SETQ n (1- n))))) (IF (SETQ pt (VLAX-INVOKE ent1 'IntersectWith ent2 ACEXTENDNONE)) (SETQ pts (CONS pt pts)) ) ) |
