查看: 2286|回复: 4
[求助]有人看得懂面域的组码么?
发表于 2007-7-13 12:51:00 | 显示全部楼层 |阅读模式
如题
可否将转化为面域前的图元的特性通过以下组码提取出来?
我不想用explode的方法,只是想知道面域及其他实体的组码的编写规则,请不要在这个帖子里讨论explode相关的问题
命令: _cget 选择对象(-1 . <图元名: 7eb86510>) (0 . "REGION") (330 . <图元名: 7eba5cf8>)
(5 . "152") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 .
"AcDbModelerGeometry") (70 . 1) (1 . "mnmoo mm m mi          ") (1 . "ni
^*+0;:,4 ^*+0\\^[ nh ^LR nmqoqnqgmo QK o  ") (1 . "mjqlffffffffffffff
fqfffffffffffffffj:rooh n:rono ") (1 . ">,27:>;:- {rn rn _nn mnmqoqnqgmo |") (1
. "=0;& {rn rn {rn {m {rn {rn |") (1 . "3*2/ {rn rn {rn {rn {l {n |") (1 .
",7:33 {rn rn {rn {rn {rn {k {rn {m |") (1 . "9><: {rn rn {rn {rn {j {l {rn {i
90-(>-; ;0*=3: 0*+ |") (1 . "300/ {rn rn {rn {rn {h {k |") (1 . "/3>1:r,*-9><:
{rn rn {rn nnkqkojfohfonkhknj nlqflnklmljklmjlji o o o n n o o 90-(>-;@) V V V
V |") (1 . "<0:;8: {rn rn {rn {g {f {rn {no -:):-,:; {j {rn |") (1 . "<0:;8:
{rn rn {rn {f {h {rn {nn -:):-,:; {j {rn |") (1 . "<0:;8: {rn rn {rn {h {g {rn
{nm -:):-,:; {j {rn |") (1 . ":;8: {rn rn {rn {nl o {nk nmqiimiljmfhmkjiof {h
{nj 90-(>-; _h *1410(1 |") (1 . ":;8: {rn rn {rn {ni o {nl iqiojllniggjlolmnl
{g {nh 90-(>-; _h *1410(1 |") (1 . ":;8: {rn rn {rn {nk o {ni
nmqikhlkilljonlnin {f {ng 90-(>-; _h *1410(1 |") (1 . "):-+:' {rn rn {rn {no o
{nf |") (1 . "):-+:' {rn rn {rn {no n {mo |") (1 . ",+->687+r<*-): {rn rn {rn
nmoqmjhifigiookgkk nlqkglghimokookloh o roqfihohmgomlmgmkomm
roqmjkkffgfnflfognf o V V |") (1 . "):-+:' {rn rn {rn {nm n {mn |") (1 .
",+->687+r<*-): {rn rn {rn nniqfjjolnonjhglmg nfqmokminmkiiflfmj o
oqjooooooooooooookk roqgiiomjkolhgkklglh o V V |") (1 . ",+->687+r<*-): {rn rn
{rn nogqonmooiijgmgoik noqminmliggfnfnmfj o oqhohnoihgnngijkhfn
oqhohnoihgnngijkhlj o V V |") (1 . "/061+ {rn rn {rn nmoqmjhifigiookgkk
nlqkglghimokookloh o |") (1 . "/061+ {rn rn {rn nogqonmooiijgmgoik
noqminmliggfnfnmfj o |") (1 . "/061+ {rn rn {rn nniqfjjolnonjhglmg
nfqmokminmkiiflfmj o |"))
发表于 2007-7-14 03:15:00 | 显示全部楼层
面域的组码就是你看到的内容.
至于1组码的内容,跟cad其他实体的组码内容完全是两回事.
 楼主| 发表于 2007-7-14 12:51:00 | 显示全部楼层
不一样么?
我一直都误认为是一样的规则呢
那如何把1后面的字符串转变成可以得出面域形状的数据呢?
发表于 2007-7-16 09:52:00 | 显示全部楼层
AutoDesk加密了的。
发表于 2007-7-16 11:01:00 | 显示全部楼层
估计是像楼上所说的,加了密。
如果你需要region的几何特性的话,只能用vla函数了.不妨参考我下面的帖子:
http://www.mjtd.com/Functions/ArticleShow.asp?ArticleID=1173
GMT+8, 2025-5-1 08:26 , Processed in 0.141260 second(s), 25 queries , Gzip On.
