查看: 3216|回复: 3
用vba如何创建面域啊?
发表于 2007-7-19 22:05:00 | 显示全部楼层 |阅读模式
我用addline方法画了几条封闭线段(线段定义的不是一个数组),用addregion想将这几条线段创建面域不知为何做不了
刚接触VBA,望高手赐教~
有没有一个方法象Autolisp那样指定两个点就可以将两点范围内的封闭曲线做成面域?
谢谢哦~~
发表于 2007-7-20 11:26:00 | 显示全部楼层
下面是我弄的一个构建面域的试验程序,你可以用选择集来构建。
Sub q()
Dim obj(0 To 1) As AcadPolyline
Dim x1(0 To 14) As Double
Dim x2(0 To 14) As Double
Dim y1(0 To 3) As Double
Dim y2(0 To 3) As Double
x1(0) = 915.532
x1(1) = 459.517
x1(2) = 0
x1(3) = 948.256
x1(4) = 461.206
x1(5) = 0
x1(6) = 948.256
x1(7) = 434.545
x1(8) = 0
x1(9) = 905.75
x1(10) = 435.993
x1(11) = 0
x1(12) = 915.532
x1(13) = 459.517
x1(14) = 0
x2(0) = 948.541
x2(1) = 458.139
x2(2) = 0
x2(3) = 956.261
x2(4) = 439.321
x2(5) = 0
x2(6) = 956.261
x2(7) = 404.46
x2(8) = 0
x2(9) = 915.497
x2(10) = 429.448
x2(11) = 0
x2(12) = 948.541
x2(13) = 458.139
x2(14) = 0
Set obj(0) = ThisDrawing.ModelSpace.AddPolyline(x1)
Set obj(1) = ThisDrawing.ModelSpace.AddPolyline(x2)
Dim regions As Variant
regions = ThisDrawing.ModelSpace.AddRegion(obj)
Dim r1 As AcadRegion
Dim r2 As AcadRegion
 Set r1 = regions(0)
 Set r2 = regions(1)
 r1.Boolean acIntersection, r2
 MsgBox "mj is :" & r1.Area
End Sub
 楼主| 发表于 2007-7-20 18:36:00 | 显示全部楼层
谢谢laoxie指教~
试试好不好用~
发表于 2007-7-23 10:38:00 | 显示全部楼层
不错,不过面域相交用的一般比较少吧!想差用的可能比较多
if regions(0)>region(1) then
r1=regions(0)
r2=regions(1)
else
 r1=regions(1)
r2=regions(0)
end if
r1.boolean acsubtraction r2
GMT+8, 2026-1-17 04:05 , Processed in 0.181954 second(s), 23 queries , Gzip On.
