(defun c:aa (/ lx xx lay D l) (zhl_registry) (setvar "cmdecho" 0) ;(while (= ent nil) (setq ent (car (entsel "\n选择要改变填充比例的对象:"))) ;) (initget "A S") (SETQ XX (GETkword "\n请选择:[改变所有此类填充(A)/<该变选择>]")) (princ) (if ent (progn (setq d (getdist "\n指定周期长度: ")) (setq lst (entget ent)) (setq l (cdr (assoc 46 lst))) (setq name (cdr (assoc 2 lst))) (if (= xx "A") (SETQ ent (ssget "x" (list (cons 2 name)))) ) (command "-hatchedit" ent "p" name (/ d l) "") ) ) (print) )
