无痕兄,你说的是不是下面这个?但如何使用到我的那段LSP里去呢? ;; Grread+osnap+GRVECS ;; Rewritten by Fools @ TheSwamp.org ;; ;; Use (grread) to get original point ;; Use (osnap) to calculate accurate point ;; Use (GRVECS) to show AutoSnapMarker ;; No return , just show the method
(DEFUN c:tmp (/ AUTOSNAPMARKERCOLOR AUTOSNAPMARKERSIZE DRAG GHOSTPT LST_OSMODE STR_OSMODE TIME DistPerPixel Bold Draftobj get_osmode YPY_StrParse YPY_GetGrvecs YPY_DrawVecs ) ;; CAB 10/5/2006 ;; Fools change a little about "," (3/3/2007) ;; ;; Function to return the current osmode setting in the form of a string ;; If (getvar "osmode") = 175 ;; (get_osmode) returns "_end,_mid,_cen,_nod,_int,_per" (DEFUN get_osmode (/ cur_mode mode$) (SETQ mode$ "") (IF (< 0 (SETQ cur_mode (GETVAR "osmode")) 16383) (MAPCAR (FUNCTION (LAMBDA (x) (IF (NOT (ZEROP (LOGAND cur_mode (CAR x)))) (IF (ZEROP (STRLEN mode$)) (SETQ mode$ (CADR x)) (SETQ mode$ (STRCAT mode$ "," (CADR x))) ) ) ) ) '((1 "_end") (2 "_mid") (4 "_cen") (8 "_nod") (16 "_qua") (32 "_int") (64 "_ins") (128 "_per") (256 "_tan") (512 "_nea") (1024 "_qui") (2048 "_app") (4096 "_ext") (8192 "_par") ) ) ) mode$ ) ;;My functions (DEFUN YPY_StrParse (str delim / ptr lst) (WHILE (SETQ ptr (VL-STRING-SEARCH delim str)) (SETQ lst (CONS (SUBSTR str 1 ptr) lst)) (SETQ str (SUBSTR str (+ ptr 2))) ) (REVERSE (CONS str lst)) ) (DEFUN YPY_GetGrvecs (pt dragpt lst / KEY) (SETQ key T) (WHILE (AND key lst) (IF (EQUAL (OSNAP dragpt (CAR lst)) pt 1E-6) (SETQ key nil) (SETQ lst (CDR lst)) ) ) (CDR (ASSOC (CAR lst) '(("_end" ((-1 1) (-1 -1)) ((-1 -1) (1 -1)) ((1 -1) (1 1)) ((1 1) (-1 1)) ) ;square ("_mid" ((0 1.414) (-1.225 -0.707)) ((-1.225 -0.707) (1.225 -0.707)) ((1.225 -0.707) (0 1.414)) ) ;triangle ("_cen" ((0 1) (-0.707 0.707)) ((-0.707 0.707) (-1 0)) ((-1 0) (-0.707 -0.707)) ((-0.707 -0.707) (0 -1)) ((0 -1) (0.707 -0.707)) ((0.707 -0.707) (1 0)) ((1 0) (0.707 0.707)) ((0.707 0.707) (0 1)) ) ;circle ("_nod" ((0 1) (-0.707 0.707)) ((-0.707 0.707) (-1 0)) ((-1 0) (-0.707 -0.707)) ((-0.707 -0.707) (0 -1)) ((0 -1) (0.707 -0.707)) ((0.707 -0.707) (1 0)) ((1 0) (0.707 0.707)) ((0.707 0.707) (0 1)) ((-1 1) (1 -1)) ((-1 -1) (1 1)) ) ;circle+cross ("_qua" ((0 1.414) (-1.414 0)) ((-1.414 0) (0 -1.414)) ((0 -1.414) (1.414 0)) ((1.414 0) (0 1.414)) ) ;square rotate 45 ("_int" ((-1 1) (1 -1)) ((-1 -1) (1 1)) ((1 0.859) (-0.859 -1)) ((-1 0.859) (0.859 -1)) ((0.859 1) (-1 -0.859)) ((-0.859 1) (1 -0.859)) ) ;cross ("_ins" ((-1 1) (-1 -0.1)) ((-1 -0.1) (0 -0.1)) ((0 -0.1) (0 -1.0)) ((0 -1.0) (1 -1)) ((1 -1) (1 0.1)) ((1 0.1) (0 0.1)) ((0 0.1) (0 1.0)) ((0 1.0) (-1 1)) ) ;two squares ("_per" ((-1 1) (-1 -1)) ((-1 -1) (1 -1)) ((0 -1) (0 0)) ((0 0) (-1 0)) ) ;half square ("_tan" ((0 1) (-0.707 0.707)) ((-0.707 0.707) (-1 0)) ((-1 0) (-0.707 -0.707)) ((-0.707 -0.707) (0 -1)) ((0 -1) (0.707 -0.707)) ((0.707 -0.707) (1 0)) ((1 0) (0.707 0.707)) ((0.707 0.707) (0 1)) ((1 1) (-1 1)) ) ;circle+line ("_nea" ((-1 1) (1 -1)) ((1 -1) (-1 -1)) ((-1 -1) (1 1)) ((1 1) (-1 1)) ) ;two triangle ("_qui") ; ??? ("_app" ((-1 1) (-1 -1)) ((-1 -1) (1 -1)) ((1 -1) (1 1)) ((1 1) (-1 1)) ((-1 1) (1 -1)) ((-1 -1) (1 1)) ) ;square+cross ("_ext" ((0.1 0) (0.13 0)) ((0.2 0) (0.23 0)) ((0.3 0) (0.33 0)) ) ;three points ("_par" ((0 1) (-1 -1)) ((1 1) (0 -1))) ;two lines ) ) ) ) ;;Use GRVECS (DEFUN YPY_DrawVecs (Pt Vecs Size Color / lst matrix) ;;no Z axis (SETQ matrix (LIST (LIST Size 0.0 0.0 (CAR pt)) (LIST 0.0 Size 0.0 (CADR pt)) (LIST 0.0 0.0 1.0 0.0) (LIST 0.0 0.0 0.0 1.0) ) ) (SETQ lst (MAPCAR 'CONS (MAPCAR (FUNCTION (LAMBDA (x) Color)) Vecs) Vecs ) ) (GRVECS (APPLY 'APPEND lst) matrix) ) ;;**************************** ;; Main Routine starts here ;;**************************** (VL-LOAD-COM) (SETQ time T) (SETQ str_osmode (get_osmode)) (SETQ lst_osmode (YPY_StrParse str_osmode ",")) (SETQ Draftobj (VLA-GET-DRAFTING (VLA-GET-PREFERENCES (VLAX-GET-ACAD-OBJECT)) ) ) (SETQ AutoSnapMarkerSize (VLA-GET-AUTOSNAPMARKERSIZE Draftobj)) (SETQ AutoSnapMarkerColor (VLA-GET-AUTOSNAPMARKERCOLOR Draftobj)) (WHILE time (grread (SETQ drag (GRREAD T 1 1))) ;;Can change like (grread T 15 2) (COND ((= (CAR drag) 5) (REDRAW) (SETQ drag (CADR drag)) (IF (or (zerop (strlen str_osmode)) (NULL (SETQ ghostpt (OSNAP drag str_osmode)))) (SETQ ghostpt drag) ;;Beacuse of mouse middle button scroll , calculate "DistPerPixel" every time (PROGN (SETQ DistPerPixel (/ (GETVAR "VIEWSIZE") (CADR (GETVAR "SCREENSIZE")))) ;;Bold (SETQ Bold (MAPCAR '* (LIST DistPerPixel DistPerPixel DistPerPixel) (LIST (+ AutoSnapMarkerSize 0.5) AutoSnapMarkerSize (- AutoSnapMarkerSize 0.5) ) ) ) (FOREACH item Bold (YPY_DrawVecs ghostpt (YPY_GetGrvecs ghostpt drag lst_osmode) item AutoSnapMarkerColor ) ) ) ) ) ((= (CAR drag) 3) (IF (NULL (SETQ ghostpt (OSNAP (CADR drag) (get_osmode)))) (SETQ ghostpt (CADR drag)) ) (REDRAW) (SETQ time nil) ) ) ) (PRINC) ;can return ghostpt if want )
