查看: 1154|回复: 1
怎样才能增加线的中心线?
发表于 2007-8-13 10:01:00 | 显示全部楼层 |阅读模式
(defun c:cl (/ s ss n ce na olderr obl oco ocm olt pl pr pt pb xr)
  (setq olderr *error* *error* ai_abort
  ocm (getvar "cmdecho")
  obl (getvar "blipmode")
  oco (getvar "cecolor")
         osnap(getvar "osmode")
  olt (getvar "celtype"))
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (setvar "osmode" 0)
  (command "_.UNDO" "_GROUP")
  (princ "\n请选择需加中心线的圆,弧.")
  (setq ss (ssget) n 0)
  (repeat (sslength ss)
     (setq s (entget (ssname ss n))
    n (1+ n)
          na (cdr (assoc 0 s)))
     (if (or (= na "CIRCLE") (= na "ARC"))
   (setq ce (cdr (assoc 10 s))
           xr (* (cdr (assoc 40 s)) 1.3)
    pl (polar ce 3.1415926 xr)
    pr (polar ce 0 xr)
    pt (polar ce 1.5707963 xr)
    pb (polar ce 4.7123889 xr))
     (command "ucs" "w")
     (command "cecolor" "1" "celtype" "center" "line" pl pr "" "line" pt pb "")
     (command "ucs" "p")
  (setvar "cmdecho" ocm)
  (setvar "cecolor" oco)
  (setvar "celtype" olt)
  (setvar "osmode" osnap)
  (setq *error* olderr)
  (command "_.UNDO" "_E")
这个中心线的工功能很好用.可以实现框选,但只能画圆或弧的中心线.有那位朋友可以增加直线的中心线?
 楼主| 发表于 2007-8-13 10:03:00 | 显示全部楼层
(DEFUN C:CL ()
 (setq old_osm (getvar "osmode"))
 (setvar "osmode" 0)
 (setq sel_id "OK"
       cl_ent1 (entsel "\n请选取直线、圆弧、圆:"))
 (while (and sel_id cl_ent1)
  (setq cl_dat1 (entget (car cl_ent1))
        cl_nam1 (cdr (assoc 0 cl_dat1)))
  (if (and (/= "LINE"   cl_nam1)
           (/= "ARC"    cl_nam1)
           (/= "CIRCLE" cl_nam1))
   (setq cl_ent1 (entsel "\r:请选取直线、&圆弧、圆:"))
   (setq sel_id nil)
 (if (and cl_ent1 (null sel_id))
   (setq cl_lay (cdr (assoc 8 cl_dat1)))
   (if (= "LINE" cl_nam1)
     (setq cl_ent2 (entsel "\n请选取另一直线:"))
     (if cl_ent2
       (setq cl_dat2 (entget (car cl_ent2))
             cl_nam2 (cdr (assoc 0 cl_dat2)))
       (if (/= "LINE" cl_nam2)
        (exit)
         (setq cl_pt1 (trans (cdr (assoc 10 cl_dat1)) 0 1)
               cl_pt2 (trans (cdr (assoc 11 cl_dat1)) 0 1)
               cl_pt3 (trans (cdr (assoc 10 cl_dat2)) 0 1)
               cl_pt4 (trans (cdr (assoc 11 cl_dat2)) 0 1)
               cl_pt5 (trans (cadr cl_ent1) 0 1))
         (if (<= (distance cl_pt1 cl_pt5) (distance cl_pt2 cl_pt5))
          (setq cl1_pt cl_pt1 cl2_pt cl_pt2)
          (setq cl1_pt cl_pt2 cl2_pt cl_pt1)
         (if (<= (distance cl_pt3 cl_pt5) (distance cl_pt4 cl_pt5))
          (setq cl3_pt cl_pt3 cl4_pt cl_pt4)
          (setq cl3_pt cl_pt4 cl4_pt cl_pt3)
         (setq cl_pnt1 (polar cl1_pt (angle cl1_pt cl3_pt) (* 0.5 (distance cl1_pt cl3_pt)))
               cl_pnt2 (polar cl2_pt (angle cl2_pt cl4_pt) (* 0.5 (distance cl2_pt cl4_pt))))
         (command "line" (polar cl_pnt1 (angle cl_pnt2 cl_pnt1) (* 0.1 (distance cl_pnt1 cl_pnt2)))
                         (polar cl_pnt2 (angle cl_pnt1 cl_pnt2) (* 0.1 (distance cl_pnt1 cl_pnt2))) "")
         (command "chprop" (entlast) "" "c" "1" "lt" "center" "la" cl_lay "")
     (setq cl_pt (trans (cdr (assoc 10 cl_dat1)) 0 1)
           cl_rad (cdr (assoc 40 cl_dat1)))
     (command "line" (list (+ (* 1.2 cl_rad) (car cl_pt)) (cadr cl_pt))
                     (list (- (car cl_pt) (* 1.2 cl_rad)) (cadr cl_pt)) "")
     (command "line" (list (car cl_pt) (+ (* 1.2 cl_rad) (cadr cl_pt)))
                     (list (car cl_pt) (- (cadr cl_pt) (* 1.2 cl_rad))) "")
 (setvar "osmode" old_osm)
这个是可以画直线、圆弧、的,但不用框选。有朋友可以改成框选吗?
GMT+8, 2025-9-20 01:40 , Processed in 0.177484 second(s), 25 queries , Gzip On.
