程序目的:对颜色随层且为同一图层中的图元进行移动,按窗选方式 程序如下,不能正常运行,请大侠修改,谢谢了: (defun c:cm () (setq dx (entget (car (entsel)))) (setq dx8 (cdr (assoc 8 dx))) (setq dx62 (cdr (assoc 62 dx))) (setq p1 (getpoint) p2 (getcorner p1)) (if (= dx62 nil) (progn (setq dx62 (cdr (assoc 62 (tblsearch "layer" dx8)))) (setq ss (ssget "w" p1 p2 (list(cons 8 dx)(cons 62 dx62)))) ) ) (setq ss (ssget "w" p1 p2 (list (cons 8 dx)(cons 62 dx62)))) (command "_.move" ss "" ) (princ) ) |
