object.Highlight HighlightFlag Object MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/all_drawing_objects.htm">All Drawing Objects, MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/idh_selectionset_object.htm">SelectionSet, MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/idh_attributeref_object.htm">AttributeReference, MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/idh_group_object.htm">Group The object or objects this method applies to. HighlightFlag Boolean; input-only TRUE: The object is highlighted.
FALSE: The existing highlight is removed from the object.
Remarks Once the highlight flag for an object has been set, a call to the MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/idh_update.htm">Update or MSITStore:D:\SMALL%20TOOLS\AutoCad%202004\help\acadauto.chm::/idh_regen.htm">Regen method is required to view the change. Note that this function does not return the current highlight status of an object. 可以看出highlight不行的 |
