查看: 1374|回复: 1
[求助]帮忙看一下程序,解答一下小弟的问题
发表于 2007-9-3 10:29:00 | 显示全部楼层 |阅读模式
Sub Example_AddMenuItem()
    ' This example creates a new menu called TestMenu and inserts a menu item
    ' into it. The menu is then displayed on the menu bar.
    ' To remove the menu after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("TestMenu")
    ' Add a menu item to the new menu
    Dim newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
    ' Display the menu on the menu bar
    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
End Sub
用这个程序想调用自己的一个窗口,该怎么弄呢?
我觉得应该是openMacro这个东西,但又不知道这句话什么意思openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
请帮忙一下啊
谢谢了
发表于 2007-9-8 14:54:00 | 显示全部楼层
openMacro是一个执行的命令,
GMT+8, 2025-5-1 22:30 , Processed in 0.182286 second(s), 24 queries , Gzip On.
