这是关于TRIM与EXTEND的LISP。使CAD2004实现2006一样的框选功能!但是发现有BUG!如果使用不当会把对象捕捉的设置清除! 很是苦恼! 请哪个大哥帮忙看看!能否改下! 如果能再加上个命令使点中曲线,单点剪切;点于空位就狂选!完全跟CAD2006一样那就最好了! 下面是LISP文件 ;(if (< (atof (substr (getvar "acadver") 1 4)) 16.2) ; (progn ;;-------------------------------------------------- (defun trim&extend (cmd / error error_end olderr ssget-g ssRedraw cm os ss1 ss2 lst) (if cmd (setq cmd "_.trim") (setq cmd "_.extend") ) (defun error (x) (error_end)) (defun error_end () (if ss1 (ss-Redraw ss1 4)) (if cm (setvar "cmdecho" cm)) (if os (setvar "osmode" os)) (setq *error* olderr) ) (setq olderr *error* *error* error) (defun ss-Redraw (ss mode) (mapcar '(lambda (x) (redraw x mode)) (vl-remove-if-not '(lambda (x) (= (type x) 'ename)) (mapcar 'cadr (ssnamex ss))) ) ) (setq cm (getvar "cmdecho") os (getvar "osmode") ) (setvar "cmdecho" 0) (setvar "osmode" 0) (defun ssget-g (msg fit / p1 p2 ss) (if (not msg) (setq msg "\n选择对象: ")) (setq p1 (getpoint msg)) (if p1 (progn (setq p2 (getcorner p1 "指定对角点: ")) (while (not p2) (if (not p2) (princ "窗口说明无效。")) (setq p2 (getcorner p1 (strcat msg "指定对角点: "))) ) (setq ss (ssget "_c" p1 p2 fit)) ) ) (list ss p1 p2) ) (princ "\n选择剪切边或 <全部选择>... ") (setq ss1 (ssget)) (while (progn (if ss1 (ss-redraw ss1 3)) (apply 'or (setq lst (cdr (setq ss2 (ssget-g "\n选择要修剪的对象: " nil))))) ) (if (car ss2) (progn (setq lst (list (car lst) (cons (caar lst) (cdadr lst)) (cadr lst) (cons (caadr lst) (cdar lst)) (car lst) ) ) (command cmd) (if ss1 (command ss1 "") (command "")) (command "_f") (apply 'command lst) (command "" "") ) ) ) (error_end) (princ) ) (defun c:w () (trim&extend T)) (defun c:z () (trim&extend nil)) ;;-------------------------------------------------- ; ) (princ) ;)
