查看: 1865|回复: 3
[求助]获取对象上附着的反应器
发表于 2007-9-24 11:43:00 | 显示全部楼层 |阅读模式
请教:根据对象名,如何获得与之关联的反应器对象?
发表于 2007-9-24 12:38:00 | 显示全部楼层
发表于 2007-9-26 08:02:00 | 显示全部楼层
;|Reply From: Esquivel, Luis
Date: May/05/03 - 06:54 (GMT)
    Re: Reactor
kevin bell,
>Is it possible to quiry an object to find out what reactors are attached to
it ???
Here are two functions that will help you:
;; will return T if an object has reactor attached
(defun HAS-REACTOR? (OBJ)
  (vl-some
    (function (lambda (X) (numberp X)))
    (mapcar (function (lambda (R) (vl-position OBJ (vlr-owners R))))
     (cdar (vlr-reactors :vlr-object-reactor))
;; this will return a list of reactors attached to the object of the type: :vlr-object-reactor
(defun WHAT-REACTOR? (OBJ)
  (vl-remove-if-not
  (if (vl-position OBJ (vlr-owners R))
    R
;;And here is another one to query to any type of reactor:
;; (attached-to obj)
;; return a list with the list of reactors or nil
(defun ATTACHED-TO (OBJ)
  (vl-remove
    NIL
    (mapcar
      (function
 (lambda (REACTOR-TYPE)
   (vl-remove-if-not
     (function
       (lambda (R)
  (cond ((and (equal REACTOR-TYPE :vlr-object-reactor)
         R
        ((and (not (equal REACTOR-TYPE
     :vlr-object-reactor
       (vl-position OBJ (vlr-data R))
         R
     (cdar (vlr-reactors REACTOR-TYPE))
      (vlr-types)
 楼主| 发表于 2007-9-26 10:55:00 | 显示全部楼层
感谢楼上的代码。
我采用的方法是:为了防止连续反应,在回调函数中先判断一个全局变量的值,若存在就不做反应。
GMT+8, 2025-6-20 04:03 , Processed in 0.374475 second(s), 26 queries , Gzip On.
