原创, 我不是做相关专业的,功能要求是别人提的,具体是否合适我也不太清楚 在其它论坛上同时发布了, ;这并不能算完整的程序,只是提供个思路 ; (vl-load-com) (defun c:bo (/ block block_lis col col_lis sel i i1 i2 cir cir_lis pat_cir_lis tem temlis p name name_lis jiaz_date b_ins t_ins) (defun b_ins (p1 b_name col / ent) (if (null (tblsearch "BLOCK" b_name)) (progn (command "insert" b_name p1) (while (> (getvar "cmdactive") 0) (command "")) (entdel (entlast)) ) ) (setq ent '((43 . 1.0) (42 . 1.0) (41 . 1.0) (0 . "INSERT")) ent (cons (cons 2 b_name) ent) ent (cons (cons 62 col) ent) ent (cons (cons 10 p1) ent) ent (reverse ent) ) (entmake ent) ) (defun t_ins (p1 s h / ent) (setq ent '((67 . 0)(0 . "TEXT")) ent (cons (cons 40 h) ent) ent (cons (cons 1 s) ent) ent (cons (cons 10 p1) ent) ent (reverse ent) ) (entmake ent) ) (setq col_lis '(1 3 4 5 6 7));颜色列表 (setq block_lis'("1" "25" "2" "40" "35" "31" "44" "10" "5" "24" "38" "20" "42" "39" "32" "26" "41" "28" "18" "34" "9" "37" "36" "29" "15" "50" "22" "27" "46" "19" "17" "16" "48" "23" "43" "49" "11" "100"));图块名称列表 (setq tol 0.001);允许绘图偏差 (setq sel (ssget '((0 . "CIRCLE")))) (setq cir_lis '() name_lis '()) (if (not (null sel)) (while (setq name (ssname sel 0)) (setq tem (entget name) temlis (list (assoc 10 tem) (* 2.0 (cdr (assoc 40 tem)))) ) (if (not (member temlis cir_lis)) (setq cir_lis (cons temlis cir_lis) name_lis (cons name name_lis) ) ) (ssdel name sel) ) ) (setq cir_lis (mapcar '(lambda (e1 e2) (append e1 (list e2))) cir_lis name_lis)) ;cir_lis格式:中心点 直径 图元名称 (setq p (getpoint "\n请输入表格插入位置:")) (setq p (trans p 1 0)) (setq i 1 ;序列号 i1 0 ;颜色序列号 i2 0 ;图块序列号 ) (t_ins (mapcar '+ p '(13.75 -10.0 0.0)) "总 和" 3.85) (t_ins (mapcar '+ p '(35.5 -3.0 0.0)) "======" 2.75) (t_ins (mapcar '+ p '(40 -5.5 0.0)) (rtos (length cir_lis) 2 0) 2.2) (setq jiaz_date (getreal "\n请输入加针<手动输入加针结果>:")) (while (> (length cir_lis) 0) (setq d (cadr (car cir_lis))) (foreach cir cir_lis (if (< (cadr cir) d) (setq d (cadr cir)) ) ) ;(alert (vl-princ-to-string d)) (setq pat_cir_lis '() tem '() ) (foreach cir cir_lis (if (equal d (cadr cir) tol) (setq pat_cir_lis (cons cir pat_cir_lis)) (setq tem (cons cir tem)) ) ) (setq cir_lis tem) (if (> (length pat_cir_lis) 0) (progn ;突出显示此类圆 (foreach cir pat_cir_lis (redraw (caddr cir) 3) ) (redraw) ;输入针径 GH")或(setq s"邮票孔")或(setq s"断线孔"这三样啊 (if (null jiaz_date) (progn (setq s (getstring (strcat "\n孔径=" (rtos d 2 3) "输入<孔径(P:PGH, Y:邮票孔, D:断线孔, 其它) ,>针径:"))) (setq ds (rtos d 2 3)) (cond ((= s "")(setq s "****")) ((or (= (substr s 1 2) "P,") (= (substr s 1 2) "p,")) (setq ds "-PGH-" s (substr s 3))) ((or (= (substr s 1 3) "P ,") (= (substr s 1 3) "p ,")) (setq ds "-PGH-" s (substr s 4))) ((or (= (substr s 1 3) "P,") (= (substr s 1 3) "p,")) (setq ds "-PGH-" s (substr s 4))) ((or (= (substr s 1 4) "P ,") (= (substr s 1 4) "p ,")) (setq ds "-PGH-" s (substr s 5))) ((or (= (substr s 1 1) "P") (= (substr s 1 1) "p")) (setq ds "-PGH-" s (substr s 2))) ((or (= (substr s 1 2) "Y,") (= (substr s 1 2) "y,")) (setq ds "邮票孔" s (substr s 3))) ((or (= (substr s 1 3) "Y ,") (= (substr s 1 3) "y ,")) (setq ds "邮票孔" s (substr s 4))) ((or (= (substr s 1 3) "Y,") (= (substr s 1 3) "y,")) (setq ds "邮票孔" s (substr s 4))) ((or (= (substr s 1 4) "Y ,") (= (substr s 1 4) "y ,")) (setq ds "邮票孔" s (substr s 5))) ((or (= (substr s 1 1) "Y") (= (substr s 1 1) "y")) (setq ds "邮票孔" s (substr s 2))) ((or (= (substr s 1 2) "D,") (= (substr s 1 2) "d,")) (setq ds "断线孔" s (substr s 3))) ((or (= (substr s 1 3) "D ,") (= (substr s 1 3) "d ,")) (setq ds "断线孔" s (substr s 4))) ((or (= (substr s 1 3) "D,") (= (substr s 1 3) "d,")) (setq ds "断线孔" s (substr s 4))) ((or (= (substr s 1 4) "D ,") (= (substr s 1 4) "d ,")) (setq ds "断线孔" s (substr s 5))) ((or (= (substr s 1 1) "D") (= (substr s 1 1) "d")) (setq ds "断线孔" s (substr s 2))) ((setq tem (vl-string-search "," s))(setq ds (substr s 1 tem) s (substr s (+ 2 tem)))) ((setq tem (vl-string-search "," s))(setq ds (substr s 1 tem) s (substr s (+ 3 tem)))) (T (princ)) ) (setq tem (rtos (atof s) 2 2)) (if (> (strlen tem)(strlen s)) (setq s tem)) ) (progn (cond ((equal d 0.99 0.001) (setq ds "-PGH-" s 1.00)) ((equal d 1.09 0.001) (setq ds "-PGH-" s 1.10)) ((equal d 1.29 0.001) (setq ds "-PGH-" s 1.30)) ((equal d 1.49 0.001) (setq ds "-PGH-" s 1.50)) ((equal d 1.01 0.001) (setq ds "邮票孔" s 1.00)) ((equal d 1.31 0.001) (setq ds "邮票孔" s 1.30)) ((equal d 1.51 0.001) (setq ds "邮票孔" s 1.50)) ((equal d 1.02 0.001) (setq ds "断线孔" s 1.00)) ((equal d 1.32 0.001) (setq ds "断线孔" s 1.30)) ((equal d 1.52 0.001) (setq ds "断线孔" s 1.50)) (T (setq ds (rtos d 2 3) s (+ d jiaz_date))) ) (setq s (rtos s 2 2)) ) ) ;(if (null s) (setq s "****")(setq s (rtos s 2 2))) ;关闭此类圆突出显示 (foreach cir pat_cir_lis (redraw (caddr cir) 4) ) (redraw) ;写序列号 i (t_ins p (rtos i 2 0) 2.75) ;确定颜色 (if (setq col (nth i1 col_lis)) (setq i1 (1+ i1)) (setq i1 1 col (car col_lis) ) ) ;确定图块名称 (if (setq block (nth i2 block_lis)) (setq i2 (1+ i2)) (setq i2 1 block (car block_lis) ) ) ;表格内插入图块 (b_ins (mapcar '+ p '(10.45 0.99 0.0)) block col) ;写孔径 (t_ins (mapcar '+ p '(17.75 0.0 0.0)) ds 2.75) ;写针径 (t_ins (mapcar '+ p '(31.6 0.0 0.0)) s 2.75) ;写数量 (t_ins (mapcar '+ p '(43.0 0.0 0.0)) (rtos (length pat_cir_lis) 2 0) 2.75) ;图上做标记 (foreach cir pat_cir_lis (b_ins (cdar cir) block col) ) (setq i (1+ i) p (polar p (/ pi 2.0) 5.5) ) ) ) ) (t_ins (mapcar '+ p '(-2.27 0.0 0.0)) "序号" 2.75) (t_ins (mapcar '+ p '(6.68 0.0 0.0)) "符号" 2.75) (t_ins (mapcar '+ p '(17.69 0.0 0.0)) "孔径" 2.75) (t_ins (mapcar '+ p '(30.83 0.0 0.0)) "针径" 2.75) (t_ins (mapcar '+ p '(41.47 0.0 0.0)) "数量" 2.75) (if (> i2 (+ (length block_lis) 1)) (alert " 直径类型超过了符号数量,部分符号重复使用了!")) (princ) ) |
