查看: 2810|回复: 2
在VBA中如何将LAYOUT中激活的视口中的图层(在当前视口中冻结)解冻,求大虾99
发表于 2007-9-28 22:43:00 | 显示全部楼层 |阅读模式
我已经知道 将LAYOUT中激活的视口中的图层(在当前视口中冻结)冻结,但是解冻不知道要怎么样才行?
请大虾指点一下,谢谢
下面是冻结的代码:
Sub VpLayerOff(strLayer As String)
Dim objEntity As AcadObject
Dim ObjPViewport As AcadObject
Dim objPViewport2 As AcadObject
Dim XdataType As Variant
Dim XdataValue As Variant
Dim I As Integer
Dim Counter As Integer
Dim PT1 As Variant
Set ObjPViewport = ThisDrawing.ActivePViewport
ObjPViewport.GetXData "ACAD", XdataType, XdataValue
For I = LBound(XdataType) To UBound(XdataType)
   If XdataType(I) = 1003 Then
       Counter = I + 1
      If XdataValue(I) = strLayer Then Exit Sub
   End If
Next
If Counter = 0 Then
       If XdataType(I) = 1002 Then Counter = I - 1
    Next
End If
XdataType(Counter) = 1003
XdataValue(Counter) = strLayer
ReDim Preserve XdataType(Counter + 1)
ReDim Preserve XdataValue(Counter + 1)
XdataType(Counter + 1) = 1002
XdataValue(Counter + 1) = "}"
ReDim Preserve XdataType(Counter + 2)
ReDim Preserve XdataValue(Counter + 2)
XdataType(Counter + 2) = 1002
XdataValue(Counter + 2) = "}"
ObjPViewport.SetXData XdataType, XdataValue
End Sub
发表于 2007-9-29 20:54:00 | 显示全部楼层
 楼主| 发表于 2007-9-29 21:30:00 | 显示全部楼层
实在是太感谢上面的大虾了
GMT+8, 2025-3-12 10:31 , Processed in 0.171404 second(s), 23 queries , Gzip On.
