查看: 1528|回复: 1
[求助]关于获取样条曲线的拟合点问题(附代码)
发表于 2007-10-16 11:29:00 | 显示全部楼层 |阅读模式
大侠们好!我现在已有一张CAD图,想通过VBA实现获取里面的所有样条曲线的拟合点的坐标,我的代码如下:
Sub Select_GetFitPoint()
    ' This example selects a spline object in model space.
    ' It then finds the coordinates of the fit points.
    ' select the spline
    ' 创建新的选择集
    Dim ssetObj As AcadSelectionSet
    'Dim splineObj As AcadSpline
    Set ssetObj = ThisDrawing.SelectionSets.Add("SSpline")
    '构建过滤器
    Dim fType As Variant, fData As Variant
    Call CreateSSetFilter(fType, fData, 0, "Spline")
    ' 提示用户选择样条曲线对象并将它们添加到选择集中。
    ' 要完成选择,按回车。
    ssetObj.SelectOnScreen fType, fData
    ZoomAll
    ' Display the coordinates of the fit points
    Dim fitPoint As Variant
    Dim index As Integer
    For index = 0 To ssetObj.NumberOfFitPoints - 1
        fitPoint = ssetObj.GetFitPoint(index)
        MsgBox "Fit point " & index + 1 & " is at " & fitPoint(0) & ", " & fitPoint(1) & ", " & fitPoint(2), , "GetFitPoint Example"
    Next
End Sub
' 创建选择集过滤器
Public Sub CreateSSetFilter(ByRef filterType As Variant, ByRef filterData As Variant, ParamArray filter())
    If UBound(filter) Mod 2 = 0 Then
        MsgBox "filter参数无效!"
        Exit Sub
    End If
    Dim fType() As Integer  ' 过滤器规则
    Dim fData() As Variant  ' 过滤器参数
    Dim count As Integer
    count = (UBound(filter) + 1) / 2
    ReDim fType(count - 1)
    ReDim fData(count - 1)
    Dim i As Integer
    For i = 0 To count - 1
        fType(i) = filter(2 * i)
        fData(i) = filter(2 * i + 1)
    Next i
    filterType = fType
    filterData = fData
End Sub
调试发现ssetObj对象不能调用GetFitPoint()这个方法,请问应该怎么改代码呢?谢谢!
发表于 2007-10-16 11:49:00 | 显示全部楼层
    For i = 0 To ssetObj.count - 1
    For index = 0 To ssetObj(i).NumberOfFitPoints - 1
        fitPoint = ssetObj(i).GetFitPoint(index)
    Next
    Next
GMT+8, 2025-2-22 16:27 , Processed in 0.189395 second(s), 24 queries , Gzip On.
