查看: 1439|回复: 2
[求助] 那个大哥蹦改下
发表于 2007-10-23 20:02:00 | 显示全部楼层 |阅读模式
(defun c:tjtk()
    (setvar "cmdecho" 0 )
    (setq os (getvar "osmode"))
    (setvar "osmode" 0 )
    (setq pt1 (getpoint "\n左上角:"))
    (setq ww (getdist pt1 "\n宽度<50>:"))
    (if (null ww) (setq ww 40.0))
    (setq hh (getdist pt1 "\n每格高度<8>:"))
    (if (null hh) (setq hh 8.0))
    (setq pt2 (polar pt1 0 ww))
    (setq pt3 (polar pt2 (* pi 1.5) hh))
    (setq pt4 (polar pt1 (* pi 1.5) hh))
    (command "pline" pt1 pt2 pt3 pt4 "c")
    (setq pt5 (polar ptl 0 (/ ww 2)))
    (setq pt6 (polar pt5 (* pi 1.5) hh))
    (command "line" pt5 pt6 "")
    (command "text" "m" (inters pt1 pt6 pt4 pt5)(/ hh 2) 0 "图块名称")
    (command "text" "m" (inters pt5 pt3 pt2 pt6)(/ hh 2) 0 "数量")
    (setq blk (tblnext "block" t))
    (while blk
           (setq blkn (assoc 2 blk))
           (setq blk_key (substr (cdr blkn) 1 1))
            (if (/= blk_key "*")
                        (setq ss (ssget "X" (list blkn)))
                        (if (null ss)
                            (setq ssn O)
                            (setq ssn (sslength ss))
                        (setq blknn (cdr blkn))
                        (setq ptl pt4 pt5 pt6 pt2 pt3)
                        (command "pllne" pt2 pt3 pt4 pt1 " ")
                        (command "llne" pt5 pt6 " ")
                        (command "text" "m" (inters ptl pt6 pt4 pr5) (/ hh 2) 0 blknn)
                        (command "text" "m" (inters pt5 pt3 pt2 pr6) (/ hh 2) 0 (itoa snn))
            (setq blk (tblnext "bLock"))
(setvar "osmode" os)
(prin1)
出现  error: bad argument type: 2D/3D point: nil
谢谢
发表于 2007-10-23 20:55:00 | 显示全部楼层
 发现很多的写错的地方,自己先检查一下:(我换成大些,你检查一下)
"pllne" --PLINE
"llne" --LINE
ptl--PT1
pr5--PT5
pr6--PT6
还有画线的点坐标还不正确。
 楼主| 发表于 2007-10-24 11:28:00 | 显示全部楼层
汗,不是那个问题吧
GMT+8, 2025-6-20 04:05 , Processed in 0.173768 second(s), 25 queries , Gzip On.
