查看: 1451|回复: 2
[求助] 取得三维实体的边界框坐标值
发表于 2007-10-26 17:51:00 | 显示全部楼层 |阅读模式
在线求助:
LISP中通过什么变量获得三维实体的边界框坐标值
 ----------------   实体    ----------------
质量:                    2301805.6628
体积:                    2301805.6628
边界框:               X: 744.6168  --  1193.0931
                      Y: 378.6073  --  529.5633
                      Z: 0.0000  --  34.0000
质心:                 X: 968.8549
                      Y: 454.0853
                      Z: 17.0000
惯性矩:               X: 4.7988E+11
                      Y: 2.2001E+12
                      Z: 2.6782E+12
惯性积:              XY: 1.0127E+12
                     YZ: 17768673854.9407
                     ZX: 37911967915.5229
旋转半径:             X: 456.5937
                      Y: 977.6636
                      Z: 1078.6720
主力矩与质心的 X-Y-Z 方向:
                      I: 4592812953.2263 沿 [1.0000 0.0000 0.0000]
                      J: 38802102436.2318 沿 [0.0000 1.0000 0.0000]
                      K: 42951434165.0980 沿 [0.0000 0.0000 1.0000]
发表于 2007-10-26 21:06:00 | 显示全部楼层
  1. (defun C:tt(/ obj llpt urpt)
  2.   (setq obj (vlax-ename->vla-object (car (entsel "\nSelect a 3D Solid: "))))
  3.   (vla-getboundingbox obj 'llpt 'urpt)
  4.   (setq llpt (vlax-safearray->list llpt)
  5. urpt (vlax-safearray->list urpt))
  6.   (alert (strcat "X:  " (rtos (car llpt) 2 4) "  --  " (rtos (car urpt) 2 4) "\n"
  7.    "Y:  " (rtos (cadr llpt) 2 4) "  --  " (rtos (cadr urpt) 2 4) "\n"
  8.    "Z:  " (rtos (caddr llpt) 2 4) "  --  " (rtos (caddr urpt) 2 4) "\n"))
  9.   (princ)
  10. )
 楼主| 发表于 2007-10-26 21:45:00 | 显示全部楼层
谢谢
GMT+8, 2025-6-20 04:07 , Processed in 0.341361 second(s), 32 queries , Gzip On.
