查看: 1225|回复: 0
无效的过程调用或参数
发表于 2007-10-31 21:03:00 | 显示全部楼层 |阅读模式
Sub cccc() '测试函数
'Private Type Point '三维点
   ' X As Single
   ' Y As Single
    'H As Single
'End Type
'Dim sqm() As Double
Dim line As AcadLine
Dim s(0 To 2) As Double
'Dim e(0 To 2) As Double
Dim s1() As Variant
Dim e1() As Variant
Dim x As Variant
Dim y As Variant
Dim h As Variant
Dim PI As Double
PI = 3.1415926
    Dim d As Double
    Dim t As Double
    Dim l As Double
    Dim r As Double
    Dim d1 As Double
    Dim e As Double
    Dim f As Double
    Dim m As Double
    Dim n2 As Double
    Dim n As Double
    Dim c1 As Double
    Dim c2 As Double
    Dim c3 As Double
    Dim c4 As Double
    Dim c5 As Double
    Dim c As Double
    Dim a As Double
    Dim b As Double
    Dim DD As Double
    Dim g As Double
    Dim m1 As Double
    Dim n1 As Double
    Dim w As Double
    Dim p As Double
    Dim q As Double
    'Dim sqm1 As Variant
    Dim sqm1(0 To 2) As Double
    Dim sqm(0 To 2) As Double
    x = 144.005: y = -14: h = 1076
    a = 29: b = 2
    c4 = (a - b) ^ (1 / 3)
    c5 = 1 / 3
  If h <= 965 Then
      d = h - 950.5
      t = 73.125 - 0.049 * d
      l = 34.94 + 3.7538 * d
      r = 176.262 + 0.2225 * d
      'GoTo zbjs
    ElseIf h <= 975 Then
      d = h - 970
      t = 72.207 + 0.0586 * d
      l = 96.186 + 1.3628 * d
      r = 180.601 + 0.2224 * d
      'GoTo zbjs
    ElseIf h <= 990 Then
      d = h - 975
      t = 72.5 - 0.0086 * d
      l = 103 + 1.4 * d
      r = 181.713 + 0.2225 * d
     ' GoTo zbjs
    ElseIf h <= 1010 Then
      d = h - 990
      t = 72.371 - 0.0086 * d
      l = 124 + 1.4 * d
      r = 185.05 + 0.2225 * d
     ' GoTo zbjs
    ElseIf h <= 1030 Then
      d = h - 1010
      t = 72.2 - 0.105 * d
      l = 152 + 1.1125 * d
      r = 189.5 + 0.245 * d
      'GoTo zbjs
    ElseIf h <= 1050 Then
      d = h - 1030
      t = 70.1 - 0.105 * d
      l = 174.25 + 1.1125 * d
      r = 194.4 + 0.345 * d
     ' GoTo zbjs
    ElseIf h <= 1070 Then
      d = h - 1050
      t = 68 - 0.145 * d
      l = 196.5 + 0.8375 * d
      r = 201.3 + 0.5769 * d
     ' GoTo zbjs
     ElseIf h <= 1090 Then
      d = h - 1070
      t = 65.1 - 0.145 * d
      l = 213.25 + 1.1375 * d
      r = 212.839 + 0.8769 * d
      GoTo zbjs
    ElseIf h <= 1110 Then
      d = h - 1090
      t = 62.2 - 0.215 * d
      l = 236 + 1.225 * d
      r = 230.377 + 1.27965 * d
      'GoTo zbjs
    ElseIf h <= 1130 Then
      d = h - 1110
      t = 57.9 - 0.215 * d
      l = 260.5 + 1.225 * d
      r = 255.97 + 1.3297 * d
     ' GoTo zbjs
    ElseIf h <= 1150 Then
      d = h - 1130
      t = 53.6 - 0.24 * d
      l = 285 + 1.175 * d
      r = 282.564 + 1.3258 * d
     ' GoTo zbjs
    ElseIf h <= 1170 Then
      d = h - 1150
      t = 48.8 - 0.24 * d
      l = 308.5 + 1.375 * d
      r = 309.08 + 1.7259 * d
     ' GoTo zbjs
    ElseIf h <= 1190 Then
      d = h - 1170
      t = 44 - 0.3375 * d
      l = 336 + 1.073 * d
      r = 343.597 + 1.5823 * d
     ' GoTo zbjs
     ElseIf h <= 1210 Then
      d = h - 1190
      t = 37.25 - 0.3375 * d
      l = 357.46 + 1.073 * d
      r = 375.243 + 1.7824 * d
     ' GoTo zbjs
    ElseIf h <= 1230 Then
      d = h - 1210
      t = 30.5 - 0.4143 * d
      l = 378.92 + 0.588 * d
      r = 410.89 + 1.6983 * d
     ' GoTo zbjs
    ElseIf h <= 1245 Then
      d = h - 1230
      t = 22.214 - 0.4143 * d
      l = 390.68 + 0.588 * d
      r = 444.856 + 1.9316 * d
      'GoTo zbjs
    End If
zbjs: d1 = 1245 - h
      e = 6 - 0.40342 * d1 + 1.20744 * d1 ^ 2 / 10 ^ 3 + 2.78123 * d1 ^ 3 / 10 ^ 7
      f = 12 + 0.440058 * d1 - 1.16241 * d1 ^ 2 / 10 ^ 3 + 1.2662856 * d1 ^ 3 / 10 ^ 6
      m = -(r ^ 2 * x)
      n2 = e + r - y
      n = 2 * r * n2 / 3
       c1 = Sqr(m ^ 2 + n ^ 3)
      c2 = (c1 - m) ^ 1/3
      c3 = (-c1 - m) ^ 1 / 3
      c = c2 + c3
           DD = e + (1 / 2) * c ^ 2 / r
         g = Atn(c / r) '* 180 / pi
      m1 = (0.5 * l * (Sqr(r ^ 2 + l ^ 2)) + 0.5 * r ^ 2 * Log(l + Sqr(r ^ 2 + l ^ 2)) - 0.5 * r ^ 2 * Log(r)) / r
      n1 = (0.5 * c * (Sqr(r ^ 2 + c ^ 2)) + 0.5 * r ^ 2 * Log(c + Sqr(r ^ 2 + c ^ 2)) - 0.5 * r ^ 2 * Log(r)) / r
      w = f + (t - f) * (n1 / m1) ^ 2.2
      p = c + 0.5 * w * Sin(g)
      q = DD - 0.5 * w * Cos(g)
      MsgBox c2
      MsgBox "x=" & p & " y= " & q
     End Sub
其中的C2值c2 = (c1 - m) ^ 1/3 提示没问题,但算出来是(c1 - m)/3的结果,若变成c2 = (c1 - m) ^ (1/3),老提示无效的过程调用或参数.
在这里请教各位高手,先行感谢
GMT+8, 2025-5-1 19:03 , Processed in 0.170626 second(s), 23 queries , Gzip On.
