查看: 1680|回复: 3
如何查找和统计这些块?
发表于 2007-11-2 15:52:00 | 显示全部楼层 |阅读模式
在我的图形中含有多个(上百个)名为“zPanel”的块,
块中有图号“DrawNO”/色卡“Color”/长度“Len”/宽度“Width”等属性,
怎么样才能将这些统计数据写入DBF文件中。(已建有相同字段的D:\CYC\DeckP.dbf文件)
发表于 2007-11-3 19:06:00 | 显示全部楼层
Sub Example_Select_text() '低等级表形式
    Dim ssetObj As AcadSelectionSet
    Dim CONUT As Integer
    CONUT = 0
    Count = ThisDrawing.SelectionSets.Count
     For I = 0 To Count - 1 '删除所有的选择集
    Set ssetObj = ThisDrawing.SelectionSets.Item(0)
      ssetObj.Delete
    Next I
   Dim sjx, dmx As AcadSelectionSet
   Dim FilterType(1) As Integer
   Dim FilterData(1) As Variant
   Set sjx = ThisDrawing.SelectionSets.Add("sjx")
   Set dmx = ThisDrawing.SelectionSets.Add("dmx")
   FilterType(0) = 2
   FilterData(0) = "TK" '是块名
   'FilterType(1) = 62
   'FilterData(1) = 10  '颜色是3
   FilterType(1) = 8
   FilterData(1) = "0"  '图层是0
   Dim mode As Integer
  Dim doc2 As AcadDocument
 Set doc2 = ThisDrawing.ModelSpace.Document
 mode = acSelectionSetAll
 'sjx.Select mode, , , FilterType, FilterData
  sjx.SelectOnScreen FilterType, FilterData '得到图框
    Dim newvarAttributes, inpoint, entry1 As Variant
    Dim ss, sss, ssss As String
    Dim sjxcount As Integer
    sjxcount = sjx.Count
     Dim templateFileName As String
   Dim DOC1 As AcadDocument
    ReDim objects(sjxcount - 1) As AcadEntity
      Dim retObjects As Variant
    Dim minExt As Variant
     Dim maxExt As Variant
     For Each ENTRY In sjx
     newvarAttributes = ENTRY.GetAttributes '得到图框块的属性,即图名图号页码
     ENTRY.GetBoundingBox minExt, maxExt '得到图框的最大最小坐标
     mode = acSelectionSetWindow 'acSelectionSetPrevious 'acSelectionSetCrossing
     ThisDrawing.Application.ZoomWindow minExt, maxExt
     dmx.Select mode, minExt, maxExt '选择图框内的对象
     ReDim objects(dmx.Count - 1) As AcadEntity
        I = 0
      For Each entry1 In dmx
      Set objects(I) = entry1
      I = I + 1
      Next entry1
      Set DOC1 = Documents.Add
     doc2.CopyObjects objects, DOC1.ModelSpace '拷贝对象到新文件中
   DOC1.SaveAs doc2.Path & "\" & newvarAttributes(1).TextString & "(" & newvarAttributes(2).TextString & ")" & newvarAttributes(0).TextString
     DOC1.Close
     dmx.Clear
     Next ENTRY
End Sub
这个功能是实现把0层按块名为“TK”的块,把一张图会成多张。在存文件名时。用到了属性,
你仔细看下吧。应可以满足你的要求。
 楼主| 发表于 2007-11-5 11:30:00 | 显示全部楼层
十分感谢您的回复,我会认真地研究您提供的源码,谢谢!
 楼主| 发表于 2007-11-9 09:52:00 | 显示全部楼层
我已经顺利的将图块中的属性提取出来,但如何才能形成Visual Foxpro6.0识别的DBF文件?
GMT+8, 2025-2-21 03:03 , Processed in 0.230750 second(s), 23 queries , Gzip On.
