查看: 1954|回复: 1
请问如何制作工具条呢?为什么这种问题都没人愿回答呢
发表于 2007-11-4 09:39:00 | 显示全部楼层 |阅读模式
在论坛里找到很多同样的问题,都没有什么好意见啊
发表于 2008-3-10 16:37:00 | 显示全部楼层
  建立CAD -- NET托管程序比较容易实现,
using System ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Interop;
using System.Runtime.InteropServices;//系统com支持
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(ClassLibrary.SLClass))]
namespace ClassLibrary
 /// <summary>
 /// Summary description for SLClass.
 /// </summary>
 public class SLClass
  public SLClass()
   // TODO: Add constructor logic here
  public void Initialize()
   Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
   ed.WriteMessage("SLTireCAD系统初始化中……");
  // Define Command "AsdkCmd1"
  [CommandMethod("InitMenuTool")]
  static public void LoginSLTireCAD() // This method can have any name
   // Put your command code here
   AcadApplication AcadApp;
   try
    AcadApp = (AcadApplication) Marshal.GetActiveObject("AutoCAD.Application");
   catch
    AcadApp = null;
   if (AcadApp!=null)
    AcadPopupMenu Mymenu=AcadApp.MenuGroups.Item(0).Menus.Add("XXXXCAD");
    Mymenu.AddMenuItem(0,"系统登陆","_LoginXXXCAD ");
    Mymenu.AddMenuItem(1,"圆","_circle ");
    Mymenu.AddSeparator(2);
    AcadPopupMenu subm=Mymenu.AddSubMenu("","子菜单");//下级菜单
    subm.AddMenuItem(0,"射线","Xline ");
    Mymenu.AddSeparator(4);
    Mymenu.AddMenuItem(5,"圆弧","_ARC ");
    Mymenu.AddMenuItem(6,"关于SLTireCAD","__AbouteSLCAD");
    Mymenu.InsertInMenuBar(14);//插入到当前菜单组14
    AcadToolbar MyToolBar=AcadApp.MenuGroups.Item(0).Toolbars.Add("SLTireCAD工具栏");
    AcadToolbarItem tbBut1 = MyToolBar.AddToolbarButton(0, "系统登陆", "系统登陆", "_LoginXXCAD\n", false);
    //tbBut1.SetBitmaps("D:\\BMP_BTN_LOGIN.bmp","D:\\BMP_BTN_LOGIN.bmp");
    AcadToolbarItem tbBut2 = MyToolBar.AddToolbarButton(2, "关于SLTireCAD", "关于XXCAD", "_AbouteXXCAD\n", false);
    //tbBut2.SetBitmaps("BMP_BTN_LOGIN.bmp","BMP_BTN_LOGIN.bmp");
    tbBut2.TagString ="关于SLTireCAD……";
    //tbBut.SetBitmaps("first.bmp", "first.bmp");
    MyToolBar.top = 100;
    MyToolBar.left =100;
    MyToolBar.Visible = true;
GMT+8, 2025-9-18 04:28 , Processed in 0.148679 second(s), 24 queries , Gzip On.
