查看: 8130|回复: 30
[求助]一个很好的生成图层的lisp,有问题,如何修改
发表于 2007-11-5 20:36:00 | 显示全部楼层 |阅读模式
,能一次生成 "图名" 颜色 线型 线宽 是否 打印 打印样式等图层特性,以前一个同事给的
下面是主程序layers.lsp
;;(cxy:layerset-add "zongtu")
(defun cxy:layerset-add (listname / file line lyrproperties)
  (cxy:StartSet)
  (cxy:Set_Var "CLAYER" (getvar "CLAYER"))
  (setq file
  (open (cxy:path (strcat "layers/" listname ".lsp")) "r")
  (read-line file)
  (while (setq line (read-line file))
    (setq lyrproperties (read line))
    (if (/= lyrproperties nil)
      (cxy:layer-new lyrproperties)
  (close file)
  (cxy:ExitSet)
(defun cxy:StartSet ()
  (if (= *cxy-RESET* nil)
      (setq
 *cxy-RESET*  T
 *cxy-OLDERR* *ERROR*
 *ERROR*      cxy:SetErrorHandler
 *cxy-UNDO*   (getvar "UNDOCTL")
      (cxy:Set_Var "CMDECHO" 0)
      (cond
 ((= *cxy-UNDO* 0)
  (command "_.UNDO" "ALL")
 ((= *cxy-UNDO* 3)
  (command "_.UNDO" "C" "ALL")
      (command "_.UNDO" "G")
(defun cxy:path (subdir / sub ddc)
  (setq sub (vl-string-left-trim "\\/" subdir))
  (setq ddc (vl-string-right-trim "\\/" (getenv "DDCPATH")))
  (setq str (strcat ddc "/" sub))
  str
(defun cxy:layer-new (lyrprops / name color lineT lineW plot pstyl)
  (setq name (nth 0 lyrprops))
  (setq color (nth 1 lyrprops))
  (setq lineT (nth 2 lyrprops))
  (setq lineW (nth 3 lyrprops))
  (setq plot (nth 4 lyrprops))
  (setq pstyl (nth 5 lyrprops))
  (defun tmp ()
    (command "_-LAYER"    "M"   name  "C" color  ""     "L"
      lineT  ""    "LW"   lineW  "" "P"    plot   ""
  (if (= (tblsearch "layer" name) nil)
    (tmp)
      (cxy:layerstate-tempsave name)
      (tmp)
      (cxy:layerstate-temprestore name)
(defun cxy:ExitSet ()
  (command "_.UNDO" "E")
  (repeat
    (length *cxy-VARLIST*)
     (setvar (caar *cxy-VARLIST*) (cadar *cxy-VARLIST*))
     (setq *cxy-VARLIST* (cdr *cxy-VARLIST*))
  (setq
    *ERROR* *cxy-OLDERR*
    *cxy-RESET* nil
  (command nil nil)
(defun cxy:SetErrorHandler (msg)
  (if (/= msg "Function cancelled")
    (princ msg)
  (command nil nil)
  (command "_.UNDO" "e")
  (if *cxy-RESET*
    (command "_.UNDO" 1)
  (cxy:ExitSet)
(defun cxy:Set_Var (var val)
  (if (not (assoc var *cxy-VARLIST*))
    (setq *cxy-VARLIST* (cons (list var (getvar var)) *cxy-VARLIST*))
  (setvar var val)
(defun cxy:layerstate-tempsave (lname / e1)
  (setq e1 (entget (tblobjname "layer" lname)))
  (setq USER1 (cdr (assoc 70 e1)))
  (setq USER2 (cdr (assoc 62 e1)))
  (setq e1
  (subst (cons 70 0)
  (assoc 70 e1)
  e1
  (entmod e1)
(defun cxy:layerstate-temprestore (lname / e1)
  (setq e1
  (subst (cons 70 USER1)
  (assoc 70 e1)
  e1
  (if (/= (minusp USER2) nil)
      (setq USER2 (* -1 LYRCOLOR))
      (setq e1
      (subst (cons 62 USER2)
      (assoc 62 e1)
      e1
  (entmod e1)
(defun cxy:path-slashes (str / new)
  (setq new str)
  (while (/= (vl-string-search "\\" new) nil)
    (setq new (vl-string-subst "/" "\\" new))
 楼主| 发表于 2007-11-5 20:38:00 | 显示全部楼层
这是我的总图图层设置,zongtu.lsp,使用时建立一个layers的文件夹,然后zongtu.lsp放入其中,
依次是"图名" 颜色 线型 线宽 是否 打印 打印样式,同时加载zongtu.lsp和layers.lsp
在命令行输入(cxy:layerset-add "zongtu")就会生成下面设置的图层,当然你可以做成下拉菜单,就方便多了,例如:
[平立剖面]^c^c^p(cxy:layerset-add "pinglipou")^p;
                   [门窗表]^c^c^p(cxy:layerset-add "menchuangbiao")^p;
                   [详图]^c^c^p(cxy:layerset-add "xiangtu")^p;
                   [说明目录]^c^c^p(cxy:layerset-add "shuomingmulu")^p;
                   [总图]^c^c^p(cxy:layerset-add "zongtu")^p;
;_________________总图________________________
;("name" color lineT lineW plot "pstyl")
("Y_用地红线" 1   "dash" 0.25 "p" "Normal");用地红线
("Z_周边建筑" 4   "continuous" 0 "p" "Normal");周边建筑
("W_文字" 30   "continuous" 0 "p" "Normal");文字说明
("W_围墙" 9   "continuous" 0 "p" "Normal");围墙
("D_地下建筑" 11   "continuous" 0 "p" "Normal");地下建筑
("F_分期建筑线" 60   "continuous" 0 "p" "Normal");分期线
("Z_坐标点" 11   "continuous" 0 "p" "Normal");坐标标注
("T_退红线" 30   "dash" 0 "p" "Normal");建筑退红线
("F_附注说明" 7   "continuous" 0.15 "p" "Normal");平立面图中的附注说明
("C_参考网格" 253   "continuous" 0.15 "p" "Normal");参考网格
("C_城市道路" 5   "continuous" 0.15 "p" "Normal");城市道路
("Q_区内道路" 7   "continuous" 0.15 "p" "Normal");区内道路
("Y_院内道路" 115   "continuous" 0.15 "p" "Normal")
("R_人行道"   2   "continuous" 0.15 "p" "Normal")
("D_道路红线" 1   "continuous" 0.15 "p" "Normal")
("D_道路中心线" 40   "center2" 0.15 "p" "Normal")
("T_停车位(场)"   93   "continuous" 0.15 "p" "Normal")
("X_现状住宅" 253   "continuous" 0.25 "p" "Normal")
("G_规划住宅" 2   "continuous" 0.5 "p" "Normal")
("G_规划公建" 30   "continuous" 0.5 "p" "Normal")
("G_规划商业" 210   "continuous" 0.5 "p" "Normal")
("S_水系" 4   "continuous" 0.15 "p" "Normal")
("C_城市行道树" 82   "continuous" 0.15 "p" "Normal")
("Q_区内行道树" 3   "continuous" 0.15 "p" "Normal")
("Q_区内景观树" 213   "continuous" 0.15 "p" "Normal")
("T_填充层" 8   "continuous" 0.15 "p" "Normal")
 楼主| 发表于 2007-11-5 20:39:00 | 显示全部楼层
不过有时会有问题,会出现大概意思,file错误的提示,有时没有问题,只能说不太完美。请懂lisp的高手看看吧,能不能完善的更好一些
发表于 2007-11-6 19:19:00 | 显示全部楼层
 楼主| 发表于 2007-11-8 07:00:00 | 显示全部楼层
是加载线型有问题,有没有愿意写一下这个问题
发表于 2007-11-9 16:33:00 | 显示全部楼层
很好很强大!
发表于 2007-11-10 09:39:00 | 显示全部楼层
可否在cad啟動時,不用輸命令,而自動加入圖層.
 楼主| 发表于 2007-11-20 01:26:00 | 显示全部楼层
看看哪位高手,能出手一下
发表于 2007-11-20 08:43:00 | 显示全部楼层
hjiea发表于2007-11-10 9:39:00可否在cad啟動時,不用輸命令,而自動加入圖層.
还要编程序吗?可以直接用模版文件。
 楼主| 发表于 2007-11-20 12:56:00 | 显示全部楼层
这样编程序时,可以把别人画的图改成我所习惯的图层,用程序可以随时生成我的图层,用模板就不太方便了。
GMT+8, 2025-5-23 20:01 , Processed in 0.212590 second(s), 29 queries , Gzip On.
