非常感谢版主的帮助,但实在不好意思,我要的不是这个。请版主帮忙看看下边这段程序,这个就是我所说的功能,一般情况下是可以运行的,但有的时候提示错误 错误类型 "type_0" ,不知道什么原因,这是原R14汉化软件里的一段程序。 (Defun c:textfit (/ setsnapang arg LL-xyz UR-x LL-y LR-xy ename TextEnt NewEnd TMP START NewPt Val LTC_% ) (progn (defun setsnapang (arg /) (setvar "snapang" (angtof (angtos (cdr (assoc 50 arg)) 0 8) 0 )) );end defun setsnapang (Defun LL-xyz (arg) ;Lower Left xyz coord (CAR (TextBox arg)) ) (Defun UR-x (arg) ;Upper Right x coord (CAADR (TextBox arg)) ) (Defun LL-y (arg) ;Lower left y coord (CADAR (TextBox arg)) ) (Defun LR-xy (arg) ;Lower right xy coord (List (UR-x arg) (LL-y arg)) ) (Setq ename (CAR (EntSel "\n选择文字 伸展/收缩:" ) ) Textent (If ename (EntGet ename) ) ) (If (= (CDR (Assoc 0 textent)) "TEXT") (Progn (initget 0 "Start") (Setq NewEnd (Distance (LR-xy Textent) (LL-xyz Textent) ) ) (setsnapang Textent) ;set snap along text entity (setvar "ORTHOMODE" 1) ;drag along the text (setq TMP (getpoint (cdr (assoc 10 Textent)) "\n起始点/<选择新结束点>: " ) ) ;(setvar "snapang" 0) (cond ((= (type TMP) 'STR) ;;new starting point to be selected (setq Start (getpoint "\n选择新起始点: ")) (if Start (progn (command "_UCS" "_E" (cdr (assoc -1 textent))) (setvar "ORTHOMODE" 1) (setq NewPt (if Start (getpoint (trans Start 0 1) "结束点: ") nil ) ) (if NewPt (setq NewPt (trans NewPt 1 0)) ) (setvar "ORTHOMODE" 0) (command "_UCS" "_W") ) ) ) ((not (null TMP)) ;;new ending point selected (setq Start (cdr (assoc 10 Textent)) NewPt TMP ) ) (t (setq Start nil NewPt nil ) ) ) (if (and Start NewPt) (progn (setq Val (Assoc 41 Textent) ;;current width factor Val (if Val (cdr Val) 1.0 ) LTC_% (* (/ (Distance Start NewPt) NewEnd ) Val ) textent (Subst (cons 41 LTC_%) (assoc 41 textent) textent ) textent (subst (cons 10 Start) (assoc 10 textent) textent ) textent (subst (cons 11 NewPt) (assoc 11 textent) textent ) ) (EntMod textent) (EntUpd (cdr (assoc -1 textent))) ) ) ;;end of points check )))) ;end defun
