查看: 1505|回复: 3
怎样取得一个封闭图形端点的坐标
发表于 2007-11-13 15:10:00 | 显示全部楼层 |阅读模式
图形是多边形
要取各个顶点的坐标.
谢谢
发表于 2007-11-16 21:46:00 | 显示全部楼层
Polyline和LWPolyline有Coordinates属性,可以参看VBA例子:
Sub Example_Coordinates()
    ' This example creates a polyline. It then uses the Coordinates
    ' property to return all the coordinates  in the polyline. It then
    ' resets one of the vertices using the Coordinates property.
    Dim plineObj As AcadPolyline
    ' Create Polyline
    Dim points(5) As Double
    points(0) = 3: points(1) = 7: points(2) = 0
    points(3) = 9: points(4) = 2: points(5) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ThisDrawing.Regen True
    ' Return all the coordinates of the polyline
    Dim retCoord As Variant
    retCoord = plineObj.Coordinates
    ' Display current coordinates for the first vertex
    MsgBox "The current coordinates of the second vertex are: " & points(3) & ", " & points(4) & ", " & points(5), vbInformation, "Coordinates Example"
    ' Modify the coordinate of the second vertex to (5,5,0). Note that in
    ' case of a lightweight Polyline, indices will be different because the points are 2D only.
    points(3) = 5
    points(4) = 5
    points(5) = 0
    plineObj.Coordinates = points
    ' Update display
    MsgBox "The new coordinates have been set to " & points(3) & ", " & points(4) & ", " & points(5), vbInformation, "Coordinates Example"
End Sub
发表于 2007-11-16 23:17:00 | 显示全部楼层
以上例子是经典例子。
 楼主| 发表于 2007-11-22 09:45:00 | 显示全部楼层
谢谢
不过
我的问题是
对已经画好的图形(边数不定,画法不定,是闭和的)
取出各个顶点坐标
目前用的
ThisDrawing.SendCommand "-Boundary" & vbCr & ptcao & "," & a(2) & vbCr & vbCr
其中"ptcao"和"a(2)"是其这个闭和区域中的一个坐标
但是无法创建
比较费解
GMT+8, 2025-5-1 19:21 , Processed in 0.181143 second(s), 24 queries , Gzip On.
