- 积分
- 5989
- 明经币
- 个
- 注册时间
- 2006-7-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
2003-11-18编的程序见http://bbs.mjtd.com/forum.php?mod=viewthread&tid=12844
在这个粘子中采用的是匿名块技术,随后McCad又改为属性块的生成方法和属性块插入后的属性修改。
本着学习态度,对下语句进一步分析。
Set objBlock = ThisDrawing.Blocks.Add(InsPnt, "*U")
ThisDrawing.Utility.PolarPoint(InsPnt, Radians(60), 12)
Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(InsertPoint, blkname, Factor, Factor, Factor, Angle)  - Sub AddCCD()
- Dim pnt As Variant
- pnt = ThisDrawing.Utility.GetPoint(, "插入点:")
- CreateCCD 0, pnt, Radians(150), 3.5, 1
- End Sub
- ' 粗糙度符号标注函数
- ' Mode为粗糙度模式,0代表表面未加工,1代表表面加工
- ' InsertPoint为插入点位置
- ' Angle为插入的角度
- ' Value粗糙度值
- ' Factor为插入的比例因子
- Function CreateCCD(Mode As Integer, InsertPoint As Variant, Angle As Double, Value As String, Factor As Double) As AcadBlockReference
- Dim objBlock As AcadBlock
- Dim InsPnt(2) As Double
- InsPnt(0) = 0: InsPnt(1) = 0: InsPnt(2) = 0
- Set objBlock = ThisDrawing.Blocks.Add(InsPnt, "*U")
- Dim Pnt2 As Variant
- Dim Pnt3 As Variant
- Dim Pnt4 As Variant
- Dim Pnt5 As Variant
- Dim Pnt6 As Variant
- Dim Pnt7 As Variant
- Dim r As Variant
- Pnt2 = ThisDrawing.Utility.PolarPoint(InsPnt, Radians(60), 12)
- Pnt3 = ThisDrawing.Utility.PolarPoint(InsPnt, Radians(120), 6)
- Pnt4 = ThisDrawing.Utility.PolarPoint(Pnt3, 0, 6)
- Pnt5 = ThisDrawing.Utility.PolarPoint(InsPnt, Radians(90), 3 / Cos(Radians(30)))
- Pnt6 = ThisDrawing.Utility.PolarPoint(Pnt4, Radians(90), 0.7)
- Pnt7 = ThisDrawing.Utility.PolarPoint(Pnt4, Radians(90), 4.2)
- r = 3 * Tan(Radians(30))
- Dim objLine As AcadLine
- Dim objCircle As AcadCircle
- Set objLine = objBlock.AddLine(InsPnt, Pnt2)
- objLine.color = acByBlock
- Set objLine = objBlock.AddLine(InsPnt, Pnt3)
- If Mode = 1 Then
- Set objLine = objBlock.AddLine(Pnt3, Pnt4)
- ElseIf Mode = 0 Then
- Set objCircle = objBlock.AddCircle(Pnt5, r)
- objCircle.color = acByBlock
- End If
- Dim objText As AcadText
- If Angle > Radians(90) And Angle <= Radians(270) Then
- Set objText = objBlock.AddText(Value, Pnt6, 3.5)
- objText.Alignment = acAlignmentTopLeft
- objText.Rotate InsPnt, Radians(180)
- objText.Move InsPnt, Pnt6
- Else
- objText.Alignment = acAlignmentBottomRight
- End If
- objText.color = acByBlock
- Dim blkname As String
- blkname = objBlock.Name
- Dim objBlockRef As AcadBlockReference
- Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(InsertPoint, blkname, Factor, Factor, Factor, Angle)
- Set CreateCCD = objBlockRef
- End Function
- Public Function PI() As Double
- PI = Atn(1) * 4
- End Function
- Private Function Degrees(Radians As Double) As Double
- Degrees = Radians / PI * 180
- End Function
- Private Function Radians(Degrees As Double) As Double
- Radians = Degrees / 180 * PI
- End Function
