查看: 2522|回复: 2
自动标注问题?
发表于 2003-5-4 22:47:00 | 显示全部楼层 |阅读模式
我是个新手。
我在这个网站看了关于面积标注的lisp程序,原先是要指定标注位置的,现在我想通过选择对象后,自动求出该面域的中心位置,将文字标注在重心位置上,我对它进行了修改,但是行不通,请教各位了!
发表于 2003-5-6 08:14:00 | 显示全部楼层
勉強可用..
(defun C:MJBZ (/        TXTSIZE         HEADTXT  PRECISION            OLDCMD
               SEL        ENT         ENTLIST  ENTNAME  VLAENT   AREA
               PT        REGENT
  (setq TXTSIZE (getvar "dimtxt"))
  (setq HEADTXT "地块总面积为: ")
  (setq PRECISION 3)
  (setq OLDCMD (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq SEL t)
  (vl-load-com)
  (while SEL
    (setq ENT (entsel "\n选取封闭多义线/面域: "))
    (if        ENT
        (setq ENTLIST (entget (car ENT)))
        (setq ENTNAME (strcase (cdr (assoc 0 ENTLIST))))
        (cond
          ((and        (wcmatch ENTNAME "*POLYLINE")
                (setq VLAENT (vlax-ename->vla-object (car ENT)))
                (= :vlax-true (vla-get-closed VLAENT))
           (setq AREA
                  (strcat HEADTXT
                          (rtos (vlax-curve-getarea VLAENT) 2 PRECISION)
           (command "_.copy" (car ENT) "" "0,0" "0,0")
           (command "region" (car ENT) "")
           (setq REGENT (entlast))
           (setq PT (vlax-get (vlax-ename->vla-object REGENT)
                              "centroid"
           (entdel (entlast))
           (command "text" "j" "c" PT TXTSIZE "" AREA)
          ((= ENTNAME "REGION")
           (command "area" "o" (car ENT))
           (setq
             AREA (strcat HEADTXT (rtos (getvar "area") 2 PRECISION))
           (setq REGENT (car ENT))
           (setq PT
                  (vlax-get (vlax-ename->vla-object REGENT) "centroid")
          (t
           (princ "\n所选对像非封闭多义线/面域")
      (setq SEL NIL)
  (setvar "cmdecho" OLDCMD)
 楼主| 发表于 2003-5-6 20:57:00 | 显示全部楼层
谢谢!龙兄!
我回加倍努力的!
GMT+8, 2025-5-16 16:34 , Processed in 0.266475 second(s), 26 queries , Gzip On.
