查看: 1168|回复: 3
[求助]倾斜标注
发表于 2007-11-28 22:21:00 | 显示全部楼层 |阅读模式
就是把线性标注和连续标注结合起来,然后尺寸界限的长度是一样的(高版本的cad连续标注好象有这功能)
图上红色字就是鼠标依次点过的地方
[url=http://www.mjtd.com/bbs/showimg.asp?BoardID=3&fileid=19066][/url]
小弟自己改了一下,可对于倾斜标注老是不行的!请高手帮忙也改进一下!
  1. (DEFUN C:DM ()
  2. ;(setvar "orthomode" 1)
  3. (if (= userr1 "") (setvar "userr1" 900.00))
  4. (setq dimjl (getvar "userr1"))
  5. (INITGET 9)
  6. (SETQ PT1 (GETPOINT "\nFirst extension line origin 尺寸界限第一点 :"))
  7. (INITGET 9)
  8. (SETQ PT2 (GETPOINT PT1 "\nSecond extension line origin 尺寸界限第二点 :"))
  9. (setq ang1 (angle pt1 pt2))
  10. (setq pt (polar pt2 (+ ang1 (* 1.5 pi)) dimjl))
  11.      (if (or (equal (car pt1) (car pt2) 0.01) (equal (cadr pt1) (cadr pt2) 0.01))
  12.        (command "_dimlinear" pt1 pt2 pt)
  13.        (command "_dimaligned" pt1 pt2 pt)
  14.      )
  15. (SETQ ANG (CDR (ASSOC 50 (ENTGET (ENTLAST)))))
  16. (COMMAND "_DIMCONTINUE")
  17. (WHILE (SETQ PT3 (GETPOINT "\nSpecify a second extension line origin 第二点 :"))
  18.   (IF (EQUAL ANG 0.0 1E-3)
  19.    (SETQ PT3 (LIST (CAR PT3) (CADR PT2) 0.0))
  20.    (SETQ PT3 (LIST (CAR PT2) (CADR PT3) 0.0))
  21.   )
  22.   (COMMAND PT3)
  23. )
  24. (COMMAND "" "")
  25. (PRINC)
  26. )
发表于 2007-11-28 23:14:00 | 显示全部楼层
 楼主| 发表于 2007-11-29 07:58:00 | 显示全部楼层
谢谢,待试用一下!
发表于 2015-4-2 11:18:49 | 显示全部楼层
下载看看是不是能用,谢谢楼主分享
GMT+8, 2025-5-23 10:17 , Processed in 0.177569 second(s), 27 queries , Gzip On.
