查看: 5721|回复: 21
各位帮我改一个图块统计程序,谢谢
发表于 2007-12-4 11:22:00 | 显示全部楼层 |阅读模式
各位帮我改一个程序,谢谢
我希望通过窗选来统计,不希望它统计整张图的块。
程序如下:
(defun c:ttt()
   (setvar "cmdecho" 0)
   (setq os (getvar "osmode"))
   (setvar "osmode" 0)
   (setq pt1 (getpoint "\n左上角: "))
   (setq ww (getdist pt1 "\n宽度 <50>: "))
   (if (null ww) (setq ww 40.0))
   (setq hh (getdist pt1 "\n每格高度 <8>: "))
   (if (null hh) (setq hh 8.0))
   (setq pt2 (polar pt1 0 ww))
   (setq pt3 (polar pt2 (* pi 1.5) hh))
   (setq pt4 (polar pt1 (* pi 1.5) hh))
   (command "pline" pt1 pt2 pt3 pt4 "c")
   (setq pt5 (polar pt1 0 (/ ww 2)))
   (setq pt6 (polar pt5 (* pi 1.5) hh))
   (command "line" pt5 pt6 "")
   (command "text" "m" (inters pt1 pt6 pt4 pt5) (/ hh 2) 0 "图块名称")
   (command "text" "m" (inters pt5 pt3 pt2 pt6) (/ hh 2) 0 "数量")
    (setq blk (tblnext "block" t))
    (while blk
      (setq blkn (assoc 2 blk))
      (setq blk_key (substr (cdr blkn) 1 1))
      (if (/= blk_key "*")
            (setq ss (ssget "X" (list blkn)))
            (if (null ss)
               (setq ssn 0)
               (setq ssn (sslength ss))
            (setq blknn (cdr blkn))
            (setq pt1 pt4 pt5 pt6 pt2 pt3)
            (command "pline" pt2 pt3 pt4 pt1 "")
            (command "text" "m" (inters pt1 pt6 pt4 pt5) (/ hh 2) 0 blknn)
            (command "text" "m" (inters pt5 pt3 pt2 pt6) (/ hh 2) 0 (itoa
ssn))
      (setq blk (tblnext "block"))
   (setvar "osmode" os)
   (prin1)
 楼主| 发表于 2007-12-4 18:40:00 | 显示全部楼层
没有那位大哥帮改一下吗?
发表于 2007-12-5 20:47:00 | 显示全部楼层
不希望它统计整张图的块,就不要这一行(setq blk (tblnext "block" t))
改成别的
发表于 2007-12-5 20:57:00 | 显示全部楼层
不知道楼主想干嘛,给个块统计的
  1. ;;;块数量carrot1983,2007.12.05
  2. ;;-------------------------------------
  3. (defun c:tt (/ DATA ELST LASTLST NAME NLST SS)
  4.   ;;ss->elst选择集->图元表
  5.   (defun ss->elst (ss / elst)
  6.     (setq i 0)
  7.     (repeat (sslength ss)
  8.       (setq elst (cons (ssname ss i) elst)
  9.      i  (1+ i)
  10.       )
  11.     )
  12.     (reverse elst)
  13.   )
  14. ;;;统计表中相同元素的个数
  15.   (defun lstsameitmnum (lst / a len x return)
  16.     (while lst
  17.       (setq a (car lst))
  18.       (setq len (length lst))
  19.       (setq lst (vl-remove-if '(lambda (x) (= a x)) lst))
  20.       ;;第一个是(- len(length lst))个
  21.       (setq return (cons (list a (- len (length lst))) return))
  22.     )
  23.     return
  24.   )
  25.   (if (setq ss (ssget '((0 . "INSERT"))))
  26.     (progn
  27.       (setq elst (ss->elst ss))
  28.       (foreach e elst
  29. (setq data (entget e))
  30. (setq name (cdr (assoc 2 data)))
  31. (setq nlst (cons name nlst))
  32.       )
  33.       (setq lastlst (lstsameitmnum nlst))
  34.       (princ "\n>>>块数量统计如下(块名,数量):\t")
  35.       (prin1 lastlst)
  36.     )
  37.     (princ "\n请重新选择")
  38.   )
  39.   (princ)
  40. )
发表于 2007-12-5 22:36:00 | 显示全部楼层
 楼主| 发表于 2007-12-7 22:43:00 | 显示全部楼层
谢谢你们,问题搞定
发表于 2007-12-10 11:50:00 | 显示全部楼层
可以统计整张图一种圆孔大小和数量吗?
发表于 2008-1-23 10:51:00 | 显示全部楼层
可以自动生成表格吗?
发表于 2008-1-23 10:56:00 | 显示全部楼层
生成的统计数是否可以根据图纸中的变化而更改~
发表于 2008-4-2 14:24:00 | 显示全部楼层
我也碰到这个问题
我也碰到这个问题
GMT+8, 2025-6-3 13:33 , Processed in 0.164341 second(s), 28 queries , Gzip On.
