可以多次放置。 在写程序的时候,在“图形分关键”的地方添加计数 (setq i 0) (command "undo" "be") ... (command "undo" "e")
(setq i (1+ i)) (command "undo" "be") ... (command "undo" "e") (setq i (1+ i)) (command "undo" "be") ... (command "undo" "e") ..........
;;i是你想要返回的次数,如果i=10,而你想要回到第7步 (command "undo" 7)
