在下面的程序代码中有将线段的长度按图层,线型汇总的命令,现在我不需要汇总,请问怎么修改 (setq YH_s2_sheet (vla-add (vlax-get-property YH_s2_exlwbk 'worksheets)) YH_s2_cells (vlax-get-property YH_s2_sheet 'cells) ) (vla-put-name YH_s2_sheet (menucmd "M=$(edtime,$(getvar,date),YYMODDHHMMSS)")) (vlax-put-property YH_s2_cells 'item 1 1 "多段线索引") (vlax-put-property YH_s2_cells 'item 1 2 "图层") (vlax-put-property YH_s2_cells 'item 1 3 "线型") (vlax-put-property YH_s2_cells 'item 1 4 "颜色") (vlax-put-property YH_s2_cells 'item 1 5 "长度") (setq YH_s2_column 2 YH_s2_tt '() ) (mapcar '(lambda(x) (setq YH_s2_layer (car x) YH_s2_linetypes (cdr x) YH_s2_layerct '() ) (mapcar '(lambda(y) (setq YH_s2_linetype (car y) YH_s2_lines (cdr y) YH_s2_column1 YH_s2_column ) (mapcar '(lambda(z) (vlax-put-property YH_s2_cells 'item YH_s2_column 1 (nth 0 z)) (vlax-put-property YH_s2_cells 'item YH_s2_column 2 YH_s2_layer) (vlax-put-property YH_s2_cells 'item YH_s2_column 3 YH_s2_linetype) (vlax-put-property YH_s2_cells 'item YH_s2_column 4 (nth 1 z)) (vlax-put-property YH_s2_cells 'item YH_s2_column 5 (nth 2 z)) (setq YH_s2_column (1+ YH_s2_column)) ) YH_s2_lines ) (vlax-put-property YH_s2_cells 'item YH_s2_column 1 (strcat "线型\"" YH_s2_linetype "\"线段长度合计")) (vlax-put-property YH_s2_cells 'item YH_s2_column 4 (strcat "=SUM(D" (itoa YH_s2_column1) ":D" (itoa (- YH_s2_column 1)) ")")) (setq YH_s2_layerct (append YH_s2_layerct (list YH_s2_column)) YH_s2_column (1+ YH_s2_column) ) ) YH_s2_linetypes ) (setq YH_s2_sum (apply 'strcat (mapcar '(lambda(i) (strcat "D" (itoa i) "+")) YH_s2_layerct)) YH_s2_sum (strcat "=" (substr YH_s2_sum 1 (- (strlen YH_s2_sum) 1))) ) (vlax-put-property YH_s2_cells 'item YH_s2_column 1 (strcat "图层\"" YH_s2_layer "\"线段长度合计")) (vlax-put-property YH_s2_cells 'item YH_s2_column 4 YH_s2_sum) (setq YH_s2_tt (append YH_s2_tt YH_s2_layerct) YH_s2_column (1+ YH_s2_column) ) ) YH_s2_data ) (setq YH_s2_sum (apply 'strcat (mapcar '(lambda(i) (strcat "D" (itoa i) "+")) YH_s2_tt)) YH_s2_sum (strcat "=" (substr YH_s2_sum 1 (- (strlen YH_s2_sum) 1))) ) (vlax-put-property YH_s2_cells 'item YH_s2_column 1 "总计") (vlax-put-property YH_s2_cells 'item YH_s2_column 4 YH_s2_sum) (vlax-release-object YH_s2_excel) ) |
