查看: 1148|回复: 0
[原创]借助Excel更改零件号
发表于 2007-12-10 15:20:00 | 显示全部楼层 |阅读模式
绘制施工图时,在件号1~50之间补插入17和18零件号,通常方法是人工来更改后面零件号。如图所示。
本人的解决方案是,将施工图里的件号图层的件号读到到Excel中,在Excel中1~50间的17、18后,插入19、20件号。采用ObjectToObject更改原施工图里件号,效率高,实用性强。程序如下。
  1. Sub ReadPartNo()
  2.   Dim xlSheet
  3.   Set xlSheet = xlApp.sheets(1)
  4.   Dim ss1 As AcadSelectionSet
  5.   Dim layername As String
  6.   Dim AcadEnt As AcadEntity
  7.   'Dim pp1 As AcadPoint, pp2 As AcadPoint
  8.   '指定图层名称
  9.   'Set pp1 = ThisDrawing.Utility.GetPoint
  10.   'Set pp2 = ThisDrawing.Utility.GetPoint
  11.   layername = "件号"
  12.   Dim tt As AcadText, MTt As AcadMText
  13.   '得到选择集
  14.   Dim gpCode(0) As Integer
  15.   Dim dataValue(0) As Variant
  16.   gpCode(0) = 8
  17.   dataValue(0) = layername
  18. '  ss1.Delete
  19.   ii = 1
  20.   Set ss1 = ThisDrawing.SelectionSets.Add("sss")
  21.   ss1.Select acSelectionSetAll, , , gpCode, dataValue
  22.   'ss1.Select acSelectionSetCrossing, pp1, pp2, , dataValue
  23. For Each AcadEnt In ss1
  24.   'Debug.Print AcadEnt.ObjectName
  25.   Select Case AcadEnt.ObjectName
  26.     Case "AcDbText"
  27.       Set tt = AcadEnt
  28.       With tt
  29.         xlSheet.cells(ii, 1).Value = .TextString
  30.         xlSheet.cells(ii, 2).Value = .InsertionPoint(0)
  31.         xlSheet.cells(ii, 3).Value = .InsertionPoint(1)
  32.         xlSheet.cells(ii, 4).Value = .Layer
  33.         xlSheet.cells(ii, 5).Value = .ScaleFactor
  34.         xlSheet.cells(ii, 6).Value = .color
  35.         xlSheet.cells(ii, 7).Value = .ObjectID
  36.         ii = ii + 1
  37.       End With
  38.     Case "AcDbMText1"
  39.       Set MTt = AcadEnt
  40.       Debug.Print "MText---", MTt.TextString
  41.   End Select
  42.
  43. Next
  44.   ss1.Delete
  45.
  46. End Sub
  47. 在Excel中插入相应零件号,更改后面的件号,按顺序添加序号要比手动在AutoCAD中更改序号要简单多。
  48. Sub ChangePartNumber()
  49.   Dim Ent As AcadEntity
  50.   Dim tt As AcadText
  51.   Dim xlSheet
  52.   Set xlSheet = xlApp.sheets(1)
  53.
  54.   For ii = 1 To 50
  55.     Set tt = ThisDrawing.ObjectIdToObject(xlSheet.cells(ii, 7).Value)
  56.     With tt
  57.       .TextString = xlSheet.cells(ii, 1).Value
  58.       .color = acByLayer
  59.       .Update
  60.     End With
  61.   Next ii
  62. End Sub
GMT+8, 2025-5-1 20:08 , Processed in 0.149728 second(s), 24 queries , Gzip On.
