查看: 3947|回复: 8
[原创]VLSP操作WORD的函数库
发表于 2007-12-11 21:15:00 | 显示全部楼层 |阅读模式
网上只有操作[shadow=255,red,2]Excel[/shadow]的函数库,却没有操作WORD的。参考EXCEL的,试着写了一些基本的操作:
希望大家来完善:
  1. ;;;预加载WORD库
  2. (Defun nbtf-vlDoc-app-Init
  3.        (/ OSVar GGG Olb8 Olb9 Olb10 Olb11 Olb12 TLB Out msg msg1 msg2)
  4.   (if *Chinese*
  5.     (setq msg  "\n 初始化微软Word "
  6.    msg1 "\042初始化Word错误\042"
  7.    msg2 (strcat
  8.    "\042 警告"
  9.    "\n ===="
  10.    "\n 无法在您的计算机上检测到微软Word97/200X/XP软件\042"
  11.         )
  12.     )
  13.     (setq msg  "\n Initializing Microsoft Word "
  14.    msg1 "\042Initialization Word Error\042"
  15.    msg2 (strcat
  16.    "\042 WARNING"
  17.    "\n ======="
  18.    "\n Can NOT detect Wordl97/200X/XP in your computer\042"
  19.          )
  20.     )
  21.   )
  22.   (if (null mswdc-wd100words)
  23.     (progn
  24.       (if (and (setq GGG
  25.         (vl-registry-read
  26.    "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\WINWORD.EXE"
  27.    "Path"
  28.         )
  29.         )
  30.         (setq GGG (strcase (strcat GGG "WINWORD.EXE")))
  31.    )
  32. (progn
  33.    (foreach OSVar (list "SYSTEMROOT"  "WINDIR"
  34.           "WINBOOTDIR"  "SYSTEMDRIVE"
  35.           "USERNAME"  "COMPUTERNAME"
  36.           "HOMEDRIVE"  "HOMEPATH"
  37.           "PROGRAMFILES"
  38.          )
  39.      (if (vl-string-search (strcat "%" OSVar "%") GGG)
  40.        (setq GGG (vl-string-subst
  41.      (strcase (getenv OSVar))
  42.      (strcat "%" OSVar "%")
  43.      GGG
  44.    )
  45.        )
  46.      )
  47.    )
  48.    (setq Olb8  (findfile (vl-string-subst "WORD8.OLB" "WINWORD.EXE" GGG)
  49.         )
  50.   Olb9  (findfile (vl-string-subst "WORD9.OLB" "WINWORD.EXE" GGG)
  51.         )
  52.   Olb10 (findfile
  53.    (vl-string-subst "WORD10.OLB" "WINWORD.EXE" GGG)
  54.         )
  55.   Olb11 (findfile
  56.    (vl-string-subst "MSWORD.OLB" "WINWORD.EXE" GGG)
  57.         )
  58.   Olb12 (findfile
  59.    (vl-string-subst "MSWORD.OLB" "WINWORD.EXE" GGG)
  60.         )
  61.    )
  62.    (cond ((= (vl-filename-base (vl-filename-directory GGG))
  63.       "OFFICE12"
  64.    ) ;_ 结束=
  65.    (setq TLB Olb12
  66.          Out "2007"
  67.    ) ;_ 结束setq
  68.   )
  69.   ((= (vl-filename-base (vl-filename-directory GGG))
  70.       "OFFICE11"
  71.    ) ;_ 结束=
  72.    (setq TLB Olb11
  73.          Out "2003"
  74.    ) ;_ 结束setq
  75.   )
  76.   (Olb10
  77.    (setq TLB Olb10
  78.          Out "XP"
  79.    ) ;_ 结束setq
  80.   )
  81.   (Olb9
  82.    (setq TLB Olb9
  83.          Out "2000"
  84.    ) ;_ 结束setq
  85.   )
  86.   (Olb8
  87.    (setq TLB Olb8
  88.          Out "97"
  89.    ) ;_ 结束setq
  90.   )
  91.   (t (setq Out "Version Unknown"))
  92.    ) ;_ 结束cond
  93.    (if TLB
  94.      (progn
  95.        (princ (strcat MSG Out "..."))
  96.        (vlax-import-type-library
  97.   :tlb-filename   TLB      :methods-prefix
  98.   "mswdm-"    :properties-prefix
  99.   "mswdp-"    :constants-prefix "mswdc-"
  100.         )
  101.      )
  102.    )
  103. )
  104. (progn
  105.    ;;(vldcl-msgbox "x" msg1 msg2)
  106.    ;;(NBTF_GetOK (strcat "关于-"msg1 "[网蜂工具箱]")msg2 "")
  107.    (princ (strcat "关于-"msg1 "[网蜂工具箱]")msg2 ""))
  108.    (exit)
  109. )
  110.       )
  111.     )
  112.   )
  113.   mswdc-wd100words
  114. )
  115. ;|
  116. Word  Application Session Progress Function
  117. 函数名 (nbtf-vlDoc-app-new ShowExcelFlag)
  118. 功能 打开一个新Word进程并新建一个文档.
  119. 参数 BOOLE T 显示, nil 隐藏
  120. 返回值 True VLOBJ Word进程的vla-object对象
  121.             Fail   BOOLE NIL
  122. 示例:
  123. (setq *wordapp* (nbtf-vlDoc-app-new T))   #<VLA-OBJECT _Application 001db27c>
  124. |;
  125. (Defun nbtf-vlDoc-app-New (UnHide / Rtn)
  126.   (if (nbtf-vlDoc-app-init)
  127.     (progn
  128.       (if *Chinese*
  129. (princ "\n 新建微软Word工作表...")
  130. (princ "\n Creating new Word Document file...")
  131.       )
  132.       (if (setq Rtn (vlax-get-or-create-object "word.Application"))
  133. (progn
  134.    (vlax-invoke-method
  135.      (vlax-get-property Rtn 'Documents)
  136.      'add
  137.    )
  138.    (if UnHide
  139.      (vla-put-visible Rtn 1)
  140.      (vla-put-visible Rtn 0)
  141.    )
  142. )
  143.       )
  144.     )
  145.   )
  146.   Rtn
  147. )
  148. ;|
  149. 功能:打开Word文件
  150. 函数名 (nbtf-vlDoc-app-open DOCfilename ShowWordFlag)
  151. 功能 新建(查找)Word进程并打开指定文档..
  152. 参数 STR DOC文档名称(全路径), 扩展名".DOC" 可选.
  153. BOOLE T 显示, nil 隐藏
  154. 返回值 True VLOBJ Word进程vla-object对象
  155. Fail BOOLE NIL
  156. 示例:
  157. (setq *wordapp* (nbtf-vlDoc-app-open "C:/test.DOC" T))   #<VLA-OBJECT _Application 001efd2c>
  158. |;
  159. ;;;打开Word文件
  160. (Defun nbtf-vlDoc-app-open
  161.        (DOCFile UnHide / Rtn)
  162.   (setq DOCFile (strcase DOCFile))
  163.   (if (null (wcmatch DOCFile "*.DOC"))
  164.     (setq DOCFile (strcat DOCFile ".DOC"))
  165.   )
  166.   (if (and (findfile DOCFile)
  167.     (setq Rtn (vlax-get-or-create-object "Word.Application"))
  168.       )
  169.     (progn
  170.       (vlax-invoke-method
  171. (vlax-get-property Rtn 'Documents)
  172. 'Open
  173. DOCFile
  174.       )
  175.       (if UnHide
  176. (vla-put-visible Rtn 1)
  177. (vla-put-visible Rtn 0)
  178.       )
  179.     )
  180.   )
  181.   Rtn
  182. )
  183. ;|
  184. Word  Application Session Progress Function
  185. 函数名 (nbtf-vlDoc-app-save WordSessionVLA-OBJECT)
  186. 功能 保存当前文档.
  187. 参数 VLOBJ Word程序进存的vla-object对象
  188. 返回 True BOOLE T
  189. Fail BOOLE NIL
  190. 示例:
  191. (nbtf-vlDoc-app-save *wordapp*)   T
  192. |;
  193. (Defun nbtf-vlDoc-app-save (wordApp)
  194.   (equal (vlax-invoke-method
  195.     (vlax-get-property wordApp "ActiveDocument")
  196.     "Save"
  197.   )
  198.   :vlax-true
  199.   )
  200. )
  201. ;|
  202. Word  Application Session Progress Function
  203. 函数名 (nbtf-vlDoc-app-saveas WordSessionVLA-OBJECT SavedFileName)
  204. 功能 另存当前文档.
  205. 参数 VLOBJ Word进程vla-object对象
  206. STR 保存DOC文件名(全路径)
  207.                 NIL 缺省文件名"DOC.DOC"保存在当前图形目录.
  208. 返回值 True STRING 保存DOC文件名(全路径)
  209. Fail BOOLE NIL
  210. 示例:
  211. (nbtf-vlDoc-app-saveas *wordapp* nil)   "C:/Temp-Folder/DOC.DOC"
  212. (nbtf-vlDoc-app-saveas *wordapp* "C:/Temp-Folder/DOC.DOC")   "C:/Temp-Folder/DOC.DOC"
  213. (nbtf-vlDoc-app-saveas *wordapp* nil)   NIL
  214. |;
  215. (Defun nbtf-vlDoc-app-saveas (WDApp Filename / Rtn)
  216.   (if (null filename)
  217.     (setq filename (strcat (getvar "dwgprefix") "DOC.DOC"))
  218.   )
  219.   (if (null (wcmatch (setq filename (strcase Filename)) "*`.DOC"))
  220.     (setq filename (strcat filename ".DOC"))
  221.   )
  222.   (if (findfile Filename)
  223.     (vl-file-delete (findfile Filename))
  224.   )
  225.   (vlax-invoke-method
  226.     (vlax-get-property WDApp "ActiveDocument")
  227.     "SaveAs"
  228.     Filename
  229.     mswd-wdFormatDocument
  230.     :vlax-False
  231.     "" ;_密码.
  232.     :vlax-True
  233.     ""
  234.     :vlax-False
  235.     :vlax-False
  236.     :vlax-False
  237.     :vlax-False
  238.     :vlax-False
  239.   )
  240.   (findfile Filename)
  241. )
  242. ;|
  243. Word  Application Session Progress Function
  244. 函数名 (nbtf-vlDoc-app-quit WordSessionVLA-OBJECT SavedFlag)
  245. 功能 退出Word并释放内存.
  246. 参数 VLOBJ Word进程vla-object对象
  247. BOOLE 是否保存当前文档, T 保存, NIL 不保存
  248. 返回值 True BOOLE NIL
  249. Fail BOOLE NIL
  250. 示例:
  251. (nbtf-vlDoc-app-quit *wordapp* nil)   nil
  252. |;
  253. (Defun nbtf-vlDoc-app-quit (WDApp SaveYN)
  254.   (if SaveYN
  255.     (vlax-invoke-method
  256.       (vlax-get-property WDApp "ActiveDocument")
  257.       'Close
  258.     )
  259.     (vlax-invoke-method
  260.       (vlax-get-property WDApp "ActiveDocument")
  261.       'Close
  262.       :vlax-False
  263.     )
  264.   )
  265.   (vlax-invoke-method WDApp 'QUIT)
  266.   (vlax-release-object WDApp)
  267.   (setq WDApp nil)
  268.   (gc)
  269. )
  270. ;|
  271. Word  Application Session Progress Function
  272. 函数名 (nbtf-vlDoc-app-kill)
  273. 功能 关闭word.
  274. 参数 NONE 不保存
  275. 返回值 True BOOLE NIL
  276. Fail BOOLE NIL
  277. 示例:
  278. (nbtf-vlDoc-app-kill T)   nil
  279. |;
  280. (Defun nbtf-vlDoc-app-kill (SaveYN / ExlObj)
  281.   (while (setq WDApp (vlax-get-object "Word.Application"))
  282.     (nbtf-vlDoc-app-quit WDApp SaveYN)
  283.   )
  284. )
[glow=255,red,2]大家来完善[/glow]
发表于 2007-12-11 21:38:00 | 显示全部楼层
 楼主| 发表于 2007-12-15 23:49:00 | 显示全部楼层
继续:
  1. ;|
  2. 获取DOCS集ID
  3. |;
  4. (defun nbtf-vldoc-get-DOCS ()
  5.   (setq *WordApp-Docs*(VLA-GET-DOCUMENTS *WordApp*))
  6. ) ;_ 结束defun
  7. ;|
  8. 获取当前DOCID
  9. |;
  10. (Defun nbtf-vldoc-get-Doc()
  11.   (setq *WordApp-Doc*(vlax-get-property *WordApp* "ActiveDocument"))
  12.   )
  13. ;;; 获取文档的 paragraphs(进行格式设置)
  14. (Defun nbtf-vldoc-get-paragraphs (doc)
  15.   (if(null doc)(setq doc(nbtf-vldoc-get-Doc)))
  16.   (MSWdP-GET-PARAGRAPHS doc)
  17. ) ;_ 结束Defun
  18. (Defun nbtf-vlDoc-Add-text
  19.        (range text / stylename texth BOLD UNDERLINE obj)
  20.   ;; 获取文档的 paragraphs(进行格式设置)
  21.   (cond ((and (= (type text) 'LIST)
  22.        (setq stylename (cdr (assoc 7 text)) ;_字体
  23.       texth     (cdr (assoc 40 text)) ;_字高
  24.       BOLD      (cdr (assoc 2 text)) ;_加粗.
  25.       UNDERLINE (cdr (assoc 3 text));_下线
  26.       text      (cdr (assoc 1 text)) ;_文字
  27.        ) ;_ 结束setq
  28.        (not text)
  29.   ) ;_ 结束and
  30. )
  31. ((vl-catch-all-error-p
  32.     (setq obj
  33.     (vl-catch-all-apply
  34.       'MSWdm-INSERTAFTER
  35.       (list
  36.         range
  37.         text
  38.       ) ;_ 结束list
  39.     ) ;_ 结束vl-catch-all-apply
  40.     ) ;_ 结束setq
  41.   ) ;_ 结束vl-catch-all-error-p
  42.    (princ (vl-catch-all-error-message obj))
  43.   nil
  44. )
  45. (T
  46.   (and BOLD (MSWdP-PUT-BOLD range 1)) ;_粗体.
  47.   (and texth (mswdp-put-size(mswdp-get-font range )texth)) ;_字高.
  48.   (and UNDERLINE(MSWdP-PUT-UNDERLINE range MSWdC-WDUNDERLINESINGLE)) ;下划线
  49. )
  50.   ) ;_ 结束cond
  51. ) ;_ 结束Defun
示例:
  1. (defun C:test (/ paragraphs pg font range)
  2. (setq *wordapp* (nbtf-vlDoc-app-new T))
  3.   (setq paragraphs (nbtf-vldoc-get-paragraphs nil))
  4.   (SETQ pg (MSWdP-GET-LAST paragraphs))
  5.   (SETQ range (MSWdP-GET-RANGE pg))
  6.   (nbtf-vlDoc-Add-text range (list(cons 1  "写了一个文本\n") '(40 . 24)))
  7. ) ;_ 结束defun
发表于 2007-12-16 09:56:00 | 显示全部楼层
呵呵 太复杂了 就像LISP操作EXCEL一样 很复杂 还是用VC好了
发表于 2007-12-18 22:33:00 | 显示全部楼层
个人认为如果要和别的程序进行嵌接最好用VC,方便。
用LISP进行操作,证明楼主能力相当的强。
谢楼主分享。
发表于 2009-1-5 10:37:00 | 显示全部楼层
Netbee楼主,你的代码很好,支持了,继续努力!
发表于 2009-1-5 10:58:00 | 显示全部楼层
高 顶一下
发表于 2011-11-18 18:35:17 | 显示全部楼层
好,
发表于 2011-11-29 22:36:31 | 显示全部楼层
好厉害啊 太厉害了
GMT+8, 2025-4-29 10:02 , Processed in 0.183026 second(s), 27 queries , Gzip On.
