这代码不知道是那位版主写的,只有内切功能,把外切也能做出来吗? (defun GetInterPoint (ent1 ent2 / ax_ent_1 ax_ent_2 intpoints points i) (setq ax_ent_1 (vlax-ename->vla-object ent1) ax_ent_2 (vlax-ename->vla-object ent2) ) (setq intpoints (vla-intersectwith ax_ent_1 ax_ent_2 acextendnone)) (setq intpoints (vlax-variant-value intpoints)) (setq i 0) (if (> (vlax-safearray-get-u-bound intpoints 1) 0) (repeat (/ (+ 1 (- (vlax-safearray-get-u-bound intpoints 1) (vlax-safearray-get-l-bound intpoints 1) ) ) 3 ) (setq points (append points (list (list (vlax-safearray-get-element intpoints i) (vlax-safearray-get-element intpoints (+ i 1)) (vlax-safearray-get-element intpoints (+ i 2)) ))) ) (setq i (+ 3 i)) ) ) points ) (defun c:DAC ( / ent pt r entc entl pts i) (setq ent (car (entsel "\n选择直线或圆弧..."))) (setq pt (getpoint "\n输入通过点:")) (setq r (getreal "\n输入半径:")) (setvar "cmdecho" 0) (command "_.circle" pt r) (setq entc (entlast)) (command "_.offset" r ent pt "") (setq entl (entlast)) (setq pts (GetInterpoint entc entl)) (entdel entc) (entdel entl) (setq i 0) (repeat (length pts) (setq pt (nth i pts)) (command "_.circle" pt r) (setq entc (entlast)) (if (= (length (GetInterpoint entc ent)) 0) (entdel entc)) (setq i (1+ i)) ) (princ) ) |
