查看: 3147|回复: 3
呵呵,关于pline的一个lsp,xd上的一个网做的.感觉挺好
发表于 2003-5-8 10:13:00 | 显示全部楼层 |阅读模式
呵呵,关于pline的一个lsp,xd上的一个网做的.感觉挺好,大家一起看看.
(defun c:mq (/ Obj ObjX Pt PtX Dist Rtn New Ortho CEcho Osmode)
  (setq        Osmode (getvar "Osmode")
        Ortho  (getvar "OrthoMode")
        CEcho  (getvar "CmdEcho")
  (setvar "CmdEcho" 0)
  (setvar "OrthoMode" 0)
  (if (setq Obj (nentsel "\n Pick (Lw)Polyline segment :"))
    (setq Pt  (cadr Obj)
          Obj (car Obj)
  (if (null (wcmatch (cdr (assoc 0 (entget Obj)))
                     "*POLYLINE"
    (alert "\n not a polyline, please re-call function!")
      (command "_.Undo" "_Group")
      (command "_.Explode" Obj)
      (setq ObjX (car (nentselp Pt))
            Dist (getvar "OffsetDist")
      (if (null
            (setq
              Dist (getdist
                     (strcat
                       "\n Enter offset distance [Minus for Through] <"
                       (rtos Dist 2 3)
        (setq Dist (getvar "OffsetDist"))
      (redraw ObjX 3)
      (princ "\n Pick offset direction :")
      (if (setq PtX (getpoint Pt))
          (setvar "osmode" 0)
          (command "_.Offset"
                   (if (> Dist 0.0)
                     Dist
                     "_T"
                   (list ObjX Pt)
                   PtX
          (while (/= (getvar "CmdNames") "")
            (command "")
          (setq Rtn (cdr (entget (entlast))))
      (command "_.Undo" "_End")
      (command "_U")
      (if Rtn
        (entmake Rtn)
  (if Osmode
    (setvar "osmode" Osmode)
  (if Ortho
    (setvar "OrthoMode" Ortho)
  (if CEcho
    (setvar "CmdEcho" CEcho)
发表于 2003-5-8 12:28:00 | 显示全部楼层
你走太快沒看到我的程序
(defun C:PLINEOFFSET (/ HOLDECHO HOLDOSMODE ENT ENT1 ENT2 DIST PNT)
  (defun SEGMENTPTS (ENT / PNT VOBJ PARAM1 PARAM2 P1 P2 SEGPTS)
    (and
      (setq VOBJ (vlax-ename->vla-object (car ENT)))
      (setq PNT (trans (cadr ENT) 1 0))
      (setq PNT (vlax-curve-getclosestpointto VOBJ PNT))
      (setq PARAM1 (vlax-curve-getparamatpoint VOBJ PNT))
      (setq PARAM1 (fix PARAM1))
      (setq PARAM2 (1+ PARAM1))
      (if (equal PARAM1 (vlax-curve-getstartparam VOBJ) 1e-10)
        (setq P1 (vlax-curve-getstartpoint VOBJ))
        (setq P1 (vlax-curve-getpointatparam VOBJ PARAM1))
      (if (equal PARAM2 (vlax-curve-getendparam VOBJ) 1e-10)
        (setq P2 (vlax-curve-getendpoint VOBJ))
        (setq P2 (vlax-curve-getpointatparam VOBJ PARAM2))
      P1
      P2
      (setq BULGE (vla-getbulge VOBJ PARAM1))
      (setq SEGPTS (list P1 P2 BULGE))
    SEGPTS
  (defun CALCBULGE (ENT / ARCRAD CENDIR HLFANG)
    (setq VX1 (nth 0 ENT)
          VX2 (nth 1 ENT)
          BLG (nth 2 ENT)
    (setq HLFANG (* 2 (atan BLG))
          CENDIR ((if (< BLG 0)
                   (- (angle VX1 VX2) HLFANG)
                   (/ pi 2)
          ARCRAD (abs (/ (/ (distance VX1 VX2) 2.0) (sin HLFANG)))
    (list
      (polar VX1 CENDIR ARCRAD)
      ARCRAD
      (* (abs HLFANG) 2.0)
  (setq HOLDECHO (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "_.undo" "_group")
  (setq HOLDOSMODE (getvar "osmode"))
  (setvar "osmode" 0)
  (while (null ENT)
    (prompt "\n拾取POLYLINE要偏移的段: ")
    (setq ENT (ssget ":S" '((0 . "*POLYLINE"))))
  (setq        ENT (list (ssname ENT 0)
                  (osnap (cadr (nth 3 (car (ssnamex ENT 0)))) "nea")
  (initget 1)
  (setq DIST (getdist (cadr ENT) "\n输入偏移距离:"))
  (initget 1)
  (setq PNT (getpoint (cadr ENT) "\n拾取方向:"))
  (setq ENT1 (SEGMENTPTS ENT))
  (if (/= (nth 2 ENT1) 0)
    (setq ENT (CALCBULGE ENT1))
    (if        (> (nth 2 ENT1) 0)
      (command "_.arc" "c" (nth 0 ENT) (nth 0 ENT1) (nth 1 ENT1))
      (command "_.arc" "c" (nth 0 ENT) (nth 1 ENT1) (nth 0 ENT1))
    (command "_.line" (nth 0 ENT1) (nth 1 ENT1) "")
  (setq ENT2 (entlast))
  (command "_.Offset" DIST ENT2 PNT "")
  (entdel ENT2)
  (setvar "osmode" HOLDOSMODE)
  (command "_.undo" "_end")
  (setvar "osmode" HOLDECHO)
发表于 2013-8-15 01:22:10 | 显示全部楼层
这个还不给个源码
 楼主| 发表于 2020-4-7 01:56:59 | 显示全部楼层
好久以前的了。现在看看还是简陋的很。Pline线这个东西。。。。
GMT+8, 2025-9-16 04:10 , Processed in 0.219716 second(s), 27 queries , Gzip On.
