查看: 976|回复: 1
[求助]这段代码为何运行不了?
发表于 2008-2-25 17:35:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
Dim textpoint(0 To 2) As Double '声明文字插入点
Dim texthight As Double
Dim textstr As String
Dim textObject As AcadText
textpoint(0) = 20
textpoint(1) = 40
textpoint(2) = 0
texthigh = 10
textstr = "AutoCAD activex/vba" '设置字符串
Set textObject = ThisDrawing.ModelSpace.AddText_(textstr, textpoint, TextHeight)
ThisDrawing.Application.ZoomExtents
textObject.Update
End Sub
以上代码是一本书上的示例,但我试着运行后出现红字的语句错,提示错误代码"438",对象不支持该属性或方法。在CAD2004和2007版运行均是同样的情况。
请问是什么原因?
 楼主| 发表于 2008-2-25 17:50:00 | 显示全部楼层
Dim textpoint(0 To 2) As Double 'ÉùÃ÷ÎÄ×Ö²åÈëµã
Dim texthEight As Double
textpoint(0) = 20
textpoint(1) = 40
textpoint(2) = 0
texthEight = 10
textstr = "autocad activex/vba" 'ÉèÖÃ×Ö·û´®
'chuanjjjjj
Set textObject = ThisDrawing.ModelSpace.AddText(textstr, textpoint, texthEight)
textObject.Update
End Sub
GMT+8, 2025-5-1 15:04 , Processed in 0.175995 second(s), 23 queries , Gzip On.
