查看: 2123|回复: 3
[求助]为什么夹点拖动会出现错误中断,怎么解决
发表于 2008-3-1 10:59:00 | 显示全部楼层 |阅读模式
为什么夹点拖动会出现错误中断,怎样解决?谢谢
我用ObjectARX做了一个剖视符号的自定义实体,可是有时候拖动夹点会弹出下面的对话框
致命错误:Unhandled Access Violation Reading 0x12c0000 Exception at 63acda70h
请大家帮帮我,万分感激
发表于 2008-3-1 11:33:00 | 显示全部楼层
自定义实体的virtual函数都重载了吗?比如getGripPoint之类的,moveGripPoint。光贴个地址没用,版本不同,异常的地址是不同的,要分析。贴点代码出来。
 楼主| 发表于 2008-3-1 11:46:00 | 显示全部楼层
请问怎么样读取多点,谢谢
都重载了,代码如下,调试发现问题出现在倒数第二个if,谢了
Acad::ErrorStatus TyIcDbSectViewSym::moveGripPointsAt (const AcDbIntArray &indices, const AcGeVector3d &offset)
 assertWriteEnabled () ;
 //----- This method is never called unless you return eNotImplemented
 //----- from the new moveGripPointsAt() method below (which is the default implementation)
  for(int i=0; i<indices.length(); ++i)
  int index = indices.at(i);
  if (index == 0)
   view_name_pnt += offset;
   break;
  if (index == 1)
   AcGePoint3d tempnt = ori_dir_pnt + offset;
   AcGeVector3d ver = ori_dir_pnt - m_pnts[0];
   AcGeVector3d ofs_ver = tempnt - m_pnts[0];
   if (ver.angleTo(ofs_ver) > 0.5 * PI)
    AcGeVector3d tempvec = m_pnts[0] - ori_dir_pnt;
    ori_dir_pnt = m_pnts[0] + tempvec;
   break;
  if (index == 2)
   AcGePoint3d tempnt = end_dir_pnt + offset;
   AcGeVector3d ver = end_dir_pnt - m_pnts[m_pnts_num - 1];
   AcGeVector3d ofs_ver = tempnt - m_pnts[m_pnts_num - 1];
    AcGeVector3d tempvec = m_pnts[m_pnts_num - 1] - end_dir_pnt;
    end_dir_pnt = m_pnts[m_pnts_num - 1] + tempvec;
   break;
  if ((2 < index) && (index < m_pnts_num + 3))
   m_pnts[index - 3] += offset;
   loca_pnts[index -3] += offset;
   if (index == 3 || index == 4 || index == m_pnts_num + 1 || index == m_pnts_num +2)
    AcGeVector3d odir_vec(m_pnts[1] - m_pnts[0]);
    AcGeVector3d oarr_vec(ori_dir_pnt - m_pnts[0]);
    if (!oarr_vec.isPerpendicularTo(odir_vec) || (oarr_vec.length() != LineLength))
     AcGePlane oplane(m_pnts[0], odir_vec);
     AcGePoint3d otempnt(ori_dir_pnt.orthoProject(oplane));
     AcGeVector3d otem_vec = otempnt - m_pnts[0];
     ori_dir_pnt = m_pnts[0] + LineLength * otem_vec.normalize();
    AcGeVector3d edir_vec(m_pnts[m_pnts_num - 2] - m_pnts[m_pnts_num -1]);
    AcGeVector3d earr_vec(end_dir_pnt - m_pnts[m_pnts_num -1]);
    if (!earr_vec.isPerpendicularTo(edir_vec) || (earr_vec.length() != LineLength))
     AcGePlane eplane(m_pnts[m_pnts_num -1], edir_vec);
     AcGePoint3d etempnt(end_dir_pnt.orthoProject(eplane));
     AcGeVector3d etem_vec = etempnt - m_pnts[m_pnts_num -1];
     ori_dir_pnt = m_pnts[m_pnts_num -1] + LineLength * etem_vec.normalize();
   break;
  if ((m_pnts_num + 2 < index) && (index < 2 * m_pnts_num + 3))
   loca_pnts[index - m_pnts_num - 3] += offset;
   break;
 return Acad::eOk;
 //return (AcDbEntity::moveGripPointsAt (indices, offset)) ;
发表于 2008-3-1 12:09:00 | 显示全部楼层
我浏览了一下你代码,我没法调,所以只能给你几点建议。
1.避免数组访问越界。
2.用AcGeVector3d时注意,是不是0向量。因为move这函数会被不断调用,对调试带来难度。再就是,你这类的基类是撒,根据不同要求,有些情况是需要调用基类的move的。要看你要做什么。
3.确定Crash是确定发生在你的代码。而不是由你产生错误,导致CAD其他地方CRASH,后一种较难调。如果发生在你的CODE。那就把倒数第二个IF全comment。运行,如果不crash,可以确定是在这里面问题,慢慢减小范围来查。comment最多造成功能不正确。若可避免crash,问题就很清楚,重新审视这段代码吧
GMT+8, 2025-5-26 02:45 , Processed in 0.162703 second(s), 23 queries , Gzip On.
