下面程序画线是地正常,可用于多线不行,要全部完成才能显示,请帮忙改下. (defun hx(tc xx /) (command "layer" "make" tc "") (setq p1(getpoint "\n第一点:")) (command "mline" "st" xx p1) (setq p1(getpoint p1 "\n下一点:")) (while p1 (command p1) (setq p1(getpoint p1 "\n下一点:")) )(command) (command "layer" "make" "0" "") (princ) ) |
