 - ;;;测试程序运行效率程序-----------------------------------------
- (defun gps->test (lst / rlst rmax rxlst start-time tlst x y z)
- (setq tlst lst)
- (setq rlst (mapcar
- '(lambda (x)
- (setq start-time (getvar "cdate"))
- (eval x)
- (* 1000000 (- (getvar "cdate") start-time))
- tlst
- (setq rmax (apply 'max rlst))
- (setq rxlst (mapcar
- '(lambda (x)
- (cond ((= 0 x) "∞")
- (T (/ rmax x))
- rlst
- (princ "\n测试程序......流逝时间(秒)......相对速度")
- (mapcar
- '(lambda (x y z)
- (mapcar
- 'princ
- (list "\n" x "......" y "......" z)
- tlst
- rlst
- rxlst
- (princ)
- ;;;示例:---------------------------------------------------
- (defun test1 (ss)
- (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
- (defun test2 (ss / n l)
- (repeat (setq n (sslength ss))
- (setq l (cons (ssname ss (setq n (1- n))) l))
- (defun test3 (ss / n e l)
- (setq n -1)
- (while (setq e (ssname ss (setq n (1+ n))))
- (setq l (cons e l))
- 命令: (setq ss (ssget))
- 命令: (gps->test '((test1 ss) (test2 ss) (test3 ss)))
- 测试程序......流逝时间(秒)......相对速度
- (TEST1 SS)......1.04308......1.0
- (TEST2 SS)......0.111759......9.33333
- (TEST3 SS)......0.0782311......13.3333
- e.g.
- (gps->test '((c:pw) (c:wq)))
