查看: 1576|回复: 2
[求助]关于lisp的版本适应问题
发表于 2008-3-5 18:30:00 | 显示全部楼层 |阅读模式
本人对lisp的了解仅仅是皮毛,求助论坛达人!万分感谢!
手里有一个计算钢筋工程量的小程序(也是以前网上下载的),以前我们用R14可以正常运行,但是现在版本升级到了CAD2002or2004可以正常导入,命令运行也没问题,就是出不了结果出来,请求达人指点一下!原程序如下:
;;钢筋表计算程序。
;;输入直径、单根长、根数。
;;命令:CA -- 计算钢筋表。
;;命令:DTW -- 由直径计算单位重。
;;命令:CAT -- 计算钢筋总重。
(defun ca_main()
  (princ (strcat "\n\n当前为" ca:row "列模式; 长度单位 " ca:c_m ";列间距 " (rtos ca:h_ 2 1) "; 文本字高 " (rtos ca:hh 2 2) "; 对齐方式 " ca:jm "。\n"))
  (initget 1 "U N C F H J")
  (setq pt1 (getpoint (strcat "列数N/单位U/变更列间距C/自由列间距F/文本字高H/对齐方式J/<给出钢筋总长" ca:jm "对齐点>: ")))
  (cond
    ((= pt1 "U")
     (if (= ca:c_m "mm") (setq ca:c_m "mm" ca:cmm 0.001) (setq ca:c_m "mm" ca:cmm 0.001))
     (ca_main)
    ((= pt1 "N")
     (if (= ca:r_w 3) (setq ca:r_w 2 ca:row "二") (setq ca:r_w 3 ca:row "三"))
     (ca_main)
    ((= pt1 "C")
     (setq c (getdist (strcat "\n给定列间距< " (rtos ca:h_ 2 1)" >: ")))
     (if (/= c nil) (setq ca:h_ c))
     (ca_main)
    ((= pt1 "F")
     (setq n6_ 0)
     (if (= ca:r_w 3)
  (initget 1)
         (setq ptx1 (car (getpoint (strcat "\n给出钢筋总长" ca:jm "对齐点: "))))
  (initget 1)
  (setq ptx2 (car (getpoint (strcat "\n给出钢筋单位重" ca:jm "对齐点: "))))
  (initget 1)
  (setq ptx3 (car (getpoint (strcat "\n给出钢筋总重" ca:jm "对齐点: "))))
  (initget 1)
  (initget 1)
    ((= pt1 "H")
     (setq c (getdist (strcat "\n给定字高< " (rtos ca:hh 2 2)" >: ")))
     (if (/= c nil) (progn (setq ca:hh c) (setvar "textsize" c)))
     (ca_main)
    ((= pt1 "J")
     (setq ca:j_m (rem (1+ ca:j_m) 3))
     (cond
       ((= ca:j_m 0) (setq ca:jm "左"))
       ((= ca:j_m 1) (setq ca:jm "中"))
       ((= ca:j_m 2) (setq ca:jm "右"))
       (t nil)
     (ca_main)
    (t
     (setq n6_ 0)
     (if (= ca:r_w 3)
       (setq ptx1 (car pt1)
       ptx2 (+ ptx1 (* 0.95 ca:h_))
      ptx3 (+ ptx1 (* 2.0 ca:h_))
      ptx3 (+ ptx1 (* 1.0 ca:h_))
  (while (> l1 0)
    (ca_smax se1 l1) (setq e01 e20 n1 (ca_f (cdr (assoc 1 e01))) se1 se0)
    (ca_smax se2 l1) (setq e02 e20 n2 (ca_n (cdr (assoc 1 e02))) se2 se0)
    (ca_smax se3 l1) (setq e03 e20 n3 (ca_n (cdr (assoc 1 e03))) se3 se0)
    (setq l1 (sslength se1)
          y  (/ (+ (caddr(assoc 10 e01)) (caddr(assoc 10 e02))
                   (caddr(assoc 10 e03))) 3)
    (setq pt1(list ptx1 y 0)
          pt2(list ptx2 y 0)
          pt3(list ptx3 y 0)
    (setq n4 (rtos (* n3 n2 ca:cmm) 2 2)
          n5 (rtos (* pi n1 n1 0.0019625) 2 3)
          n6 (rtos (* (atof n5) (atof n4)) 2 2)
          n6_(+ n6_ (atof n6))
    (ca_mktext n4 pt1)
    (if (= ca:r_w 3) (ca_mktext n5 pt2))
    (ca_mktext n6 pt3)
(defun ca_prw(/ p_w)
  (setq pt (getpoint (strcat "\n合计钢筋总重" ca:jm "对齐点: ")))
  (if (/= pt nil)
    (ca_mktext (rtos n6_ 2 2) pt)
      (initget "Yes No")
      (setq p_w (getkword "\n取消合计总重? Yes or <No>?"))
      (if (/= p_w "Yes")
        (ca_prw)
(defun ca_f(e1)
  (cond
    ((and (> (ascii e1) 48)(<= (ascii e1) 57)) e1)
    ((= (ascii e1) 37)
     (setq e1(substr e1 3))
     (cond
       ((= (ascii e1) 49) (setq e1 (substr e1 4)))
       (t (setq e1 (substr e1 2)))
  (setq e1 (atof e1))
(defun ca_n(e1 / t1 nt nt1)
  (setq nt "" nt1 "")
  (while (/= e1 "")
    (setq t1 (substr e1 1 1) e1 (substr e1 2))
    (if (or (= t1 ".") (and (>= (ascii t1) 48) (<= (ascii t1) 57)))
      (setq nt1 (strcat nt1 t1))
        (if (or (= t1 "x") (= t1 "X")) (setq t1 "*"))
        (cond
          ((= (ascii nt1) 46) (setq nt1 (strcat "0" nt1)))
          ((= (type (read nt1)) 'INT) (setq nt1 (strcat nt1 ".0")))
          (t nil)
        (setq nt (strcat nt nt1 t1) nt1 "")
  (if (/= nt1 "")
      (cond
        (t nil)
      (setq nt (strcat nt nt1))
  (setq e1 (c:cal nt))
(defun ca_smax(se l_ / e10 y0 i e1 e2 yi y0)
  (setq e10 (ssname se 0)
        e20 (entget e10)
        y0 (caddr(assoc 10 e20))
        i 0 se0 (ssadd)
  (if (/= l_ 1)
    (repeat (- l_ 1)
      (setq i  (+ i 1)
            e1 (ssname se i)
            e2 (entget e1)
            yi (caddr(assoc 10 e2))
      (if (> yi y0)
        (progn (ssadd e10 se0) (setq e20 e2 y0 yi e10 e1))
        (ssadd e1 se0)
(defun ca_mktext(str pt10 / sty)
  (entmake
    (list
      '(0 . "TEXT")
      (cons 1 str)
      (cons 10 pt10)
      (cons 11 pt10)
      (cons 7 (setq sty (getvar "textstyle")))
      (cons 40 ca:hh)
      (assoc 41 (tblsearch "style" sty))
      (cons 51 (cdr (assoc 50 (tblsearch "style" sty))))
      '(71 . 0)
      (cons 72 ca:j_m)
;      (cons 73 :j2)
(defun c:ca(/ se0 se1 se2 se3 l1 l2 l3 a_ e01 e02 e03 n6_ e20 y olderr c
     pt1 pt2 pt3 ptx1 ptx2 ptx3 n1 n2 n3 n4 n5 n6)
  (setq olderr *error*)
  (defun *error*(s)
    (if (= s "Function cancelled") (setq *error* olderr))
  (command "color" (getvar "cecolor"))
  (prompt "\n拾取钢筋直径: ")
  (setq a_ 2 se1 (ssget '((0 . "TEXT"))))
  (if (/= se1 nil) (progn (setq l1 (sslength se1) a_ 0)) (princ "\n未选择物体."))
  (while (= a_ 0)
    (prompt "\n拾取钢筋长度: ")
    (setq se2 (ssget '((0 . "TEXT"))))
    (if (/= se2 nil) (setq l2 (sslength se2)))
    (if (= l2 l1) (setq a_ 1) (princ "\n选择集长度不同! "))
  (if (/= se1 nil) (setq a_ 0))
  (while (= a_ 0)
    (prompt "\n拾取钢筋根数: ")
    (setq se3 (ssget '((0 . "TEXT"))))
    (if (/= se3 nil) (setq l3 (sslength se3)))
    (if (= l3 l1) (setq a_ 1) (princ "\n选择集长度不同! "))
  (if (= ca:cmm nil) (setq ca:cmm 0.001 ca:c_m "mm"))
  (if (= ca:r_w nil) (setq ca:r_w 3 ca:row "三"))
  (if (= ca:jm nil) (setq ca:jm "右" ca:j_m 2))
  (if (= ca:hh nil) (setq ca:hh (getvar "textsize")))
  (if (= ca:h_ nil)
      (if (>= ca:hh 1.0)
        (setq ca:h_ (* (expt 10.0 (+ (fix (/ (log ca:hh) (log 10))) 1)) 2.0))
        (setq ca:h_ (* (expt 10.0 (fix (/ (log ca:hh) (log 10)))) 2.0))
  (if (= a_ 1) (progn (ca_main) (ca_prw)))
(defun ca_dw()
  (princ (strcat "\n当前文本字高 " (rtos ca:hh 2 2) "; 对齐方式 " ca:jm ".\n"))
  (initget 1 "H J")
  (setq pt1 (getpoint (strcat "\n文本字高H/对齐方式J/<给出钢筋" t1 ca:jm "对齐点: >")))
  (cond
    ((= pt1 "H")
     (ca_dw)
    ((= pt1 "J")
     (cond
       (t nil)
     (ca_dw)
    (t nil)
(defun c:dtw(/ se1 se0 l1 pt1 e01 e02 y n1 e20 t1 olderr)
  (defun *error*(s)
  (princ "\n拾取钢筋直径:")
  (setq se1 (ssget '((0 . "TEXT"))))
  (if (/= se1 nil)
      (setq l1 (sslength se1) t1 "单位重")
      (ca_dw)
      (while (> l1 0)
        (ca_smax se1 l1)
        (setq e01 e20
              se1 se0
              l1 (sslength se1)
              y  (caddr(assoc 10 e01))
              n1 (ca_f (cdr(assoc 1 e01)))
              pt1(list (car pt1) y 0)
              n1 (rtos (* pi n1 n1 0.0019625) 2 3)
        (ca_mktext n1 pt1)
    (princ "\n未选择物体.")
(defun c:cat(/ se1 l1 pt1 e01 n1 i olderr)
  (defun *error*(s)
  (princ "\n拾取钢筋重量:")
  (if (/= se1 nil)
      (setq l1 (sslength se1) t1 "合计总重")
      (ca_dw)
      (setq i -1 nt 0)
      (repeat l1
        (setq i (+ i 1)
              e01 (entget(ssname se1 i))
              n1 (atof (cdr(assoc 1 e01)))
              nt (+ nt n1)
      (ca_mktext (rtos nt 2 2) pt1)
    (princ "\n未选择物体.")
(if (= (type c:cal) 'LIST) (arxload "geomcal.arx"))
(princ "\n**************************************************************")
(princ "\n CA -- 钢筋表计算。 ")
(princ "   DTW -- 钢筋单位重计算。")
(princ "   CAT -- 钢筋重量合计。")
发表于 2008-3-6 09:04:00 | 显示全部楼层
好象就是ENTMAKE文字不对。
  (entmake
    (list
      '(0 . "TEXT")
      '(100 . "AcDbEntity")
      '(410 . "Model")
      '(8 . "0")
      '(100 "AcDbText")
      (cons 10 pt10)
      (cons 40 ca:hh)
      (cons 1 str)
      '(71 . 0)
      (cons 72 ca:j_m)
      (cons 11 pt10)
      '(210 0.0 0.0 1.0
   '(100 "AcDbText")
;      (cons 73 :j2)
发表于 2008-3-11 08:08:00 | 显示全部楼层
      '(210 0.0 0.0 1.0
缺括号
GMT+8, 2025-12-18 04:08 , Processed in 0.150872 second(s), 27 queries , Gzip On.
