; Program Name: directory.lsp
; Created By: xshrimp (Email: xshrimp@163.com)
; (URL: http://shlisp.ys168.com/)
; Date Created: 3-7-08
; Function: 列出给定路径下所有路径名(包含子目录)或者文件名(包含子目录)
;|函数类似vl-directory-files
语法
(gps->directory-files directory pattern directories)
功能
说明
1)参数 directory 为字符串,指定要收集文件的目录。
若未指定该参数或参数为 nil,那么gps->directory-files 使用当前目录。
2)参数 pattern 为字符串,包含文件名的 DOS 方式。
如果未指定该参数或参数为 nil,gps->directory-files 假定为 "*.*"。
3)directories 为整数型,指定返回的表中是否包含路径名。可以指定下列值之一:
-1 仅列出目录。
0 列出文件和目录(缺省值)。
1 仅列出文件。
返回值:
文件和路径列表。若没有符合指定方式的文件,则返回 nil。
;测试
(gps->directory-files "D:\\xx" nil 1)
(gps->directory-files "D:\\Downloads" "*.exe" 1) - (defun gps->directory-files (directory pattern directories / allpathlst gps->get-path lst n pathlst x y)
- (if (null pattern) (setq pattern "*.*"))
- (if (null directories) (setq directories 0))
- ;返回目录下的所有子目录
- ;(gps->get-allpath "E:\\Program Files")
- ;(gps->get-allpath "f:\\tu")
- (defun gps->get-allpath(directory pattern / allpathlst lst n pathlst x gps->get-path)
- (if (= (type directory) 'STR)
- (progn
- (setq directory (vl-string-right-trim "\\/ " directory))
- (setq allpathlst (list directory))
- (defun gps->get-path (directory / lst n pathlst x)
- (if (and (setq lst (vl-directory-files directory nil -1));仅目录
- (setq lst (vl-remove-if '(lambda (x) (or (= "." x)(= ".." x))) lst))
- (progn
- (setq pathlst (mapcar '(lambda(x)(strcat directory "\" x) ) lst))
- (setq allpathlst (append allpathlst pathlst))
- (foreach n pathlst (gps->get-path n ))
- );end if
- (gps->get-path directory)
- allpathlst
- ;返回目录下的所有目录及子目录的文件
- ;(gps->get-allfile directory pattern)
- ;(gps->get-allfile "D:\\Downloads" "*.exe")
- (defun gps->get-allfile(directory pattern / x y)
- (apply
- 'append
- (mapcar
- '(lambda (x)
- (mapcar
- '(lambda (y)
- (strcat x "\" y)
- (vl-directory-files x pattern 1);仅仅文件
- (gps->get-allpath directory pattern)
- (cond
- ((= -1 directories) (if (= pattern "*.*")(gps->get-allpath directory pattern)));仅列出目录
- ((= 0 directories)
- (if (/= pattern "*.*")
- (gps->get-allfile directory pattern)
- (apply
- 'append
- (list
- ((= 1 directories) (gps->get-allfile directory pattern));仅列出文件
