程序如下(vl-load-com) (defun c:tc (/ IsCurve ent1 ent2 pt1 pt2 p11 p12 p21 p22 start end obj1 obj2 osmode ) ; Check an entity is a curve or not (defun IsCurve (ename / name) (if ename (progn (setq name (cdr (assoc 0 (entget ename)))) (cond ((= name "LWPOLYLINE") T ) ((= name "pOLYLINE") T ) ((= name "CIRCLE") T ) ((= name "ARC") T ) ((= name "LINE") T ) ((= name "ELLIPSE") T ) ((= name "SPLINE") T ) (T NIL ) ) ) NIL ) ) ;; Main Program (setvar "cmdecho" 0) (vl-cmdf "_.undo" "g") (setq osmode (getvar "osmode")) (setvar "osmode" 0) (setq ent1 (entsel "选择第一条曲线:")) (if (IsCurve (car ent1)) (progn (if (IsCurve (car (setq ent2 (entsel "\n选择第二条曲线:")))) (progn (setq pt1 (cadr ent1) obj1 (vlax-ename->vla-object (car ent1)) pt2 (cadr ent2) obj2 (vlax-ename->vla-object (car ent2)) ) (setq start (vlax-curve-getstartpoint obj1) end (vlax-curve-getendpoint obj1) ) (if (< (distance start pt1) (distance end pt1)) (setq p11 start p12 (vlax-curve-getfirstderiv obj1 (vlax-curve-getstartparam obj1) ) p12 (mapcar '+ p11 p12 ) ) (setq p11 end p12 (vlax-curve-getfirstderiv obj1 (vlax-curve-getendparam obj1) ) p12 (mapcar '- p11 p12 ) ) ) (setq start (vlax-curve-getstartpoint obj2) end (vlax-curve-getendpoint obj2) ) (if (< (distance start pt2) (distance end pt2)) (setq p21 start p22 (vlax-curve-getfirstderiv obj2 (vlax-curve-getstartparam obj2) ) p22 (mapcar '+ p21 p22 ) ) (setq p21 end p22 (vlax-curve-getfirstderiv obj2 (vlax-curve-getendparam obj2) ) p22 (mapcar '- p21 p22 ) ) ) (vl-cmdf "_.spline" p11 p21 "" p12 p22) ) ) ) ) (setvar "osmode" osmode) (vl-cmdf "_.undo" "e") ) |
