最近,我编写了一个关于四条直线倒圆角的程序。CAD命令只能对两条直线进行倒圆角,可是风管一般都是双线,当遇到两段风管进行倒圆角的时候,就要执行两次命令。故我编写了以下程序,以实现一次命令四直线倒角的功能。但是,程序执行到最后三行的时候,出现问题。于是,我把程序中每一行单独拷贝出来在CAD中执行却又是正确的,不知为何,请高手指点一二,程序如下: (defun c:DW (/ a b c d e f) (defun getmidpoint(pt1 pt2) (polar pt1 (angle pt1 pt2) (* (distance pt1 pt2) 0.5)) ) (setq a (getint "请输入倒角半径")) (setq b (getint "请输入管径")) (setq c (entsel "请选择倒角直线")) (setq d (entsel "请选择倒角直线")) (command "fillet" "r" a "fillet" c d) (setq e (entlast)) (setq f (cdr (assoc 10 (entget e)))) (setq a1 (car f)) (setq a2 (cadr f)) (setq g (cdr (assoc 10 (entget (car c))))) (setq a3 (car g)) (setq a4 (cadr g)) (setq h (cdr (assoc 10 (entget (car d))))) (setq a5 (car h)) (setq a6 (cadr h)) (setq y1 (+ a4 (/ (* 50 (- a4 a2)) (- a3 a1)))) (setq x1 (+ a3 50)) (setq i (list x1 y1)) (if (< (distance f i) (distance f g)) (progn (setq y1 (+ a4 (/ (* 50 (- a2 a4)) (- a3 a1)))) (setq x1 (- a3 50)) (setq i (list x1 y1)) );progn );if (command "offset" b c i "") (setq of1 (cdr (assoc 10 (entget (entlast))))) (setq of2 (cdr (assoc 11 (entget (entlast))))) (setq ob1 (getmidpoint of1 of2)) (setq y3 (+ a6 (/ (* 50 (- a6 a2)) (- a5 a1)))) (setq x3 (+ a5 50)) (setq j (list x3 y3)) (if (< (distance f j) (distance f h)) (progn (setq y3 (+ a6 (/ (* 50 (- a2 a6)) (- a5 a1)))) (setq x3 (- a5 50)) (setq j (list x3 y3)) );progn );if (command "offset" b d j "") (setq of4 (cdr (assoc 11 (entget (entlast))))) (setq of3 (cdr (assoc 10 (entget (entlast))))) (setq ob2 (getmidpoint of3 of4)) (setq m (+ a b)) (command "fillet" "r" m "fillet" ob1 ob2) (command "erase" ob1 "") (command "erase" ob2 "") ) 谢谢! |
