查看: 2399|回复: 4
如何让用户指定的线条放在其他图形之上?
发表于 2008-3-21 22:52:00 | 显示全部楼层 |阅读模式
大家知道画图的时候后画的线会放在其他图形之上,而如果先画线再放置图形则图形会吧线遮住,请问如何能够把这些遮住的线放到其他图形之上。
发表于 2008-3-22 11:33:00 | 显示全部楼层
待性里面调整线的高度
 楼主| 发表于 2008-3-22 22:37:00 | 显示全部楼层
什么意思啊,我现在是在二维的环境下,哪来高度啊!
发表于 2008-3-23 11:21:00 | 显示全部楼层
  1. Sub Example_SortentsTable()
  2.     ' This example creates a SortentsTable object and
  3.     ' changes the draw order.    ' Set drawing to display lineweights and create a True Color object
  4.     Dim ACADPref As AcadDatabasePreferences
  5.     Set ACADPref = ThisDrawing.Preferences
  6.     ACADPref.LineWeightDisplay = True
  7.     Dim MyColorObjOne As AcadAcCmColor
  8.     Set MyColorObjOne = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
  9.     Call MyColorObjOne.SetRGB(80, 100, 244)
  10.
  11.     ' Draw a polyline
  12.     Dim plineObj As AcadPolyline
  13.     Dim points(0 To 8) As Double
  14.     points(0) = 4: points(1) = 4: points(2) = 0
  15.     points(3) = 3: points(4) = 5: points(5) = 0
  16.     points(6) = 6: points(7) = 20: points(8) = 0
  17.     Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
  18.     plineObj.Lineweight = acLnWt211
  19.     Call MyColorObjOne.SetRGB(90, 110, 150)
  20.     plineObj.TrueColor = MyColorObjOne    ' Draw a line
  21.     Dim lineObj As AcadLine
  22.     Dim startPoint(0 To 2) As Double
  23.     Dim endPoint(0 To 2) As Double
  24.     startPoint(0) = 5: startPoint(1) = 13: startPoint(2) = 0
  25.     endPoint(0) = 5: endPoint(1) = 27: endPoint(2) = 0
  26.     Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
  27.     lineObj.Lineweight = acLnWt211
  28.     Call MyColorObjOne.SetRGB(50, 80, 230)
  29.     lineObj.TrueColor = MyColorObjOne
  30.
  31.     ' Draw a circle
  32.     Dim circleObj As AcadCircle
  33.     Dim centerPoint(0 To 2) As Double
  34.     Dim radius As Double
  35.     centerPoint(0) = 10: centerPoint(1) = 15: centerPoint(2) = 0#
  36.     radius = 5#
  37.     Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
  38.     circleObj.Lineweight = acLnWt211
  39.     Call MyColorObjOne.SetRGB(60, 200, 220)
  40.     circleObj.TrueColor = MyColorObjOne
  41.     ZoomAll
  42.     AcadApplication.Update
  43.
  44.     'Gxet an extension dictionary and, if necessary, add a SortentsTable object
  45.     Dim eDictionary As Object
  46.     Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary
  47.     ' Prevent failed GetObject calls from throwing an exception
  48.     On Error Resume Next
  49.     Dim sentityObj As Object
  50.     Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS")
  51.     On Error GoTo 0
  52.     If sentityObj Is Nothing Then
  53.          ' No SortentsTable object, so add one
  54.          Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable")
  55.     End If
  56.
  57.     Dim ObjIds(2) As Long
  58.     ObjIds(0) = plineObj.ObjectID
  59.     ObjIds(1) = lineObj.ObjectID
  60.     ObjIds(2) = circleObj.ObjectID
  61.
  62.     Dim varObject As AcadObject
  63.     Set varObject = ThisDrawing.ObjectIdToObject(ObjIds(2))
  64.     Dim arr(0) As AcadObject
  65.     Set arr(0) = varObject
  66.
  67.     'Move the circle object to the bottom
  68.     sentityObj.MoveToBottom arr
  69.     AcadApplication.Update
  70.
  71. End Sub
 楼主| 发表于 2008-3-25 20:57:00 | 显示全部楼层
谢谢版主了,版主真是有问必答啊!
GMT+8, 2025-5-1 15:18 , Processed in 0.177776 second(s), 23 queries , Gzip On.
