查看: 1381|回复: 1
[求助]ACAD不能运行VBA了?
发表于 2008-3-22 18:08:00 | 显示全部楼层 |阅读模式
我想请教各位高手:
 我有一个VBA程序原来是可以在AutoCAD 2007上正常运行的,但当我装上Autodesk Inventor 2008后,VBA 就不能运行了,在别的机上实验也是如此(各位可以试试),但如果再装一个其他版本的ACAD,那又可以运行,我想请高手告诉我为什么,能不能不装两个ACAD而解决问题?
谢谢了!
发表于 2008-3-25 12:57:00 | 显示全部楼层
To use an AutoCAD VBA sample or view its code
1. Start AutoCAD and drag a sample into AutoCAD.
2. On the AutoCAD Tools menu, click Macro > Macros.
3. In the Macros dialog box, in the Macro list, select a macro to use or view.
4. Do one of the following:
   * To use the selected macro, click Run.
   * To view the code of the selected macro in the VBA Integrated Development
     Environment (VBA IDE), click Edit.
GMT+8, 2025-7-16 07:09 , Processed in 0.160298 second(s), 23 queries , Gzip On.
