请教一下,用LISP对图层进行操作,冻结后再解冻,图层上的东西就看不到了,用REGEN REDRAW REDRAWALL ZOOM命令都没用,用移动(ALL)一下,就可以显示出来了,为什么会这样,怎么解决? 用法: (layer1 "freez")全部冻结 (LAYER1 "THAW")全部解冻 (LAYER1 "ON")全部开启 (LAYER1 "OFF")全部关闭 (LAYER1 "LOCK")全部锁住 (LAYER1 "UNLOCK")全部解琐 ;程序来自XD (defun layer1(do / CORD_LAYER CLAY LAYEN LAYEN_DATA LAYERLIST LAYERNAME) (setq cord_layer (tblnext "layer" t)) (setq layerlist nil) (SETQ CLAY (GETVAR "CLAYER")) (while cord_layer (setq layername (cdr(assoc 2 cord_layer))) (setq layerlist (cons layername layerlist)) (setq cord_layer (tblnext "layer")) ) (cond ((= (strcase do) "OFF") (foreach item layerlist (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (setq layen_data (subst (cons 62 (* -1 (abs(cdr(assoc 62 layen_data))))) (assoc 62 layen_data) layen_data )) (entmod layen_data) ) )) ((= (strcase do) "ON") (foreach item layerlist (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (setq layen_data (subst (cons 62 (abs(cdr(assoc 62 layen_data)))) (assoc 62 layen_data) layen_data )) (entmod layen_data) ) )) ((= (strcase do) "THAW") (foreach item layerlist (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (IF (= (boole 1 (cdr (assoc 70 layen_data)) 1) 1) (setq layen_data (subst (cons 70 (1- (cdr(assoc 70 layen_data)))) (assoc 70 layen_data) layen_data )) ) (entmod layen_data) ) )) ((= (strcase do) "FREEZ") (foreach item layerlist (IF (/= CLAY ITEM) (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (IF (= (boole 1 (CDR (assoc 70 layen_data)) 1) 0) (setq layen_data (subst (cons 70 (1+ (cdr(assoc 70 layen_data)))) (assoc 70 layen_data) layen_data )) ) (entmod layen_data) ) )) ) ((= (strcase do) "LOCK") (foreach item layerlist (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (IF (= (boole 1 (CDR (assoc 70 layen_data)) 4) 0) (setq layen_data (subst (cons 70 (+ (CDR (assoc 70 layen_data)) 4)) (assoc 70 layen_data) layen_data )) ) (entmod layen_data) ) ) ) ((= (strcase do) "UNLOCK") (foreach item layerlisT (progn (setq layen (tblobjname "layer" item)) (setq layen_data (entget layen)) (IF (= (boole 1 (CDR (assoc 70 layen_data)) 4) 4) (setq layen_data (subst (cons 70 (- (CDR (assoc 70 layen_data)) 4)) (assoc 70 layen_data) layen_data )) ) (entmod layen_data) ) ) ) ) (princ) ) |
