查看: 1044|回复: 2
[求助]在vba中如何编程将坐标系转换到一根直线上?
发表于 2008-3-23 21:23:00 | 显示全部楼层 |阅读模式
 如题。在下刚学vba。如何编程获得用户输入两点后,画一直线,然后将坐标系转换到该直线上?谢谢!
 楼主| 发表于 2008-3-25 22:39:00 | 显示全部楼层
Sub Example_ActiveUCS()
    Dim ucsObj As AcadUCS
    Dim origin As Variant
    Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As Double
    Dim viewportObj As AcadViewport
    Dim x As Double, y As Double, z As Double, aa As Double, bb As Double, dd As Double
    Dim dist As Double
    ' Set the viewportObj variable to the activeviewport
    Set viewportObj = ThisDrawing.ActiveViewport
    Dim startPnt As Variant
    Dim endPnt As Variant
    Dim prompt1 As String
    Dim prompt2 As String
    prompt1 = vbCrLf & "Enter the start point of the line: "
    prompt2 = vbCrLf & "Enter the end point of the line: "
    ' 获取第一点
    startPnt = ThisDrawing.Utility.GetPoint(, prompt1)
    ' 获取第二点
    endPnt = ThisDrawing.Utility.GetPoint(, prompt2)
    ' 使用输入的两个点创建一条直线
    ThisDrawing.ModelSpace.AddLine startPnt, endPnt
    ThisDrawing.Application.ZoomAll
    ' 计算 point1 和 point2 之间的距离
    x = startPnt(0) - endPnt(0)
    y = startPnt(1) - endPnt(1)
    z = startPnt(2) - endPnt(2)
    dist = Sqr((Sqr((x ^ 2) + (y ^ 2)) ^ 2) + (z ^ 2))
    '显示计算出来的距离
    MsgBox "The distance between the points is: " _
                  & dist, , "Calculate Distance"
    aa = Abs(endPnt(1) - startPnt(1))
    bb = Abs(endPnt(0) - startPnt(0))
    dd = (aa * aa) / bb
    origin = startPnt
   xAxisPoint(0) = origin(0) + 1: xAxisPoint(1) = origin(1): xAxisPoint(2) = 0
   yAxisPoint(0) = origin(0): yAxisPoint(1) = origin(1) + 1: yAxisPoint(2) = 0
   Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
    xAxisPoint(0) = bb: xAxisPoint(1) = aa: xAxisPoint(2) = 0
    yAxisPoint(0) = -dd: yAxisPoint(1) = aa: yAxisPoint(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "TestUCS")
    ThisDrawing.ActiveUCS = ucsObj
    MsgBox "The new UCS is " & ucsObj.Name, vbInformation, "ActiveUCS Example"
    aa = 0
    bb = 0
    dd = 0
End Sub
但是以上程序仅在第一点选择wcs原点时才有效,否则就会提示y轴与x轴不垂直.能不能用translatecoordinates转换呢?但是我不会用,请斑竹赐教.不胜感激!
发表于 2008-3-26 11:30:00 | 显示全部楼层
xAxisPoint和yAxisPoint是两轴上的点,而不是向量
    Dim xAxisPoint
    Dim yAxisPoint
    Dim oLine As AcadLine
    endPnt = ThisDrawing.Utility.GetPoint(startPnt, prompt2)
    Set oLine = ThisDrawing.ModelSpace.AddLine(startPnt, endPnt)
    Dim pnt(2) As Double
    origin = startPnt
    xAxisPoint = ThisDrawing.Utility.PolarPoint(startPnt, oLine.Angle, 1)
    yAxisPoint = ThisDrawing.Utility.PolarPoint(startPnt, oLine.Angle + Atn(1) * 2, 1)
End Sub
GMT+8, 2025-2-22 18:45 , Processed in 0.211915 second(s), 25 queries , Gzip On.
