LISP程序如下: ;;;读取外部坐标点文件,并部分主程序 (defun c:rdf1() (setq os(getvar "osmode")) (setvar "osmode" 0);;关闭捕捉功能 (setvar "cmdecho" 0) (setvar "pdmode" 34) (setq ffn (getfiled "选取文件" "" "pot" 2)) (setq dima (getreal "输入金丝直径(um) :")) (setq ff (open ffn "r")) (setq data (read-line ff)) ;;;注意是- 不是_ 返回文件的该行字符串 (setq mm (strlen data)) ;;(while (/= data '() ) (while (/= mm 0 ) (setq p "" pp "" ppp '() i 1 j 1) ;;j=1可以控制后面的使TXT前面的空格不被计算在内 (setq nn (strlen data));;;返回字符串的个数 (repeat nn (setq p (substr data i 1));;;返回第i个起始 1个字长长度的字符 ;;(princ "\np ") (princ p) (if (/= p " ") (progn (setq pp (strcat pp p)) ;;;将多个字符串结合成一个长的字符串后返回 (setq j 2) ;;;设定J=2主要是给数字后面空一格用 ) ) (if (and (= p " ") (> j 1)) ;;判断是否是空格,当第一个空格时,加上;第二个开始后空格不加上,直到出现后续非空格为止 (progn (setq ppp (cons pp ppp) pp "") ;;cons将新的前置元素和列表结合为新的列表 (setq j (- j 1)) ;;已经空一格后J减去1,使第二个空格不被连入后面的数值 ) ) ;;(princ "\n ppp0: ") (princ ppp) (setq i (1+ i)) ) ;;repeat结束 (setq ppp (cons pp ppp)) (setq ppp (reverse ppp));;;返回原列表相反的顺序 (draw_wires);;调用子程序 (getmn) ;;调用中点子程序 (setq pt1 (list x1 y1 z)) (setq pt2 (list x2 y2 z)) (setq pm (list am bm z)) ;;取得中心点 (princ "\npm ") (princ k) (princ "= ") (princ pm) (princ "\n ") (setq cont (itoa k)) (setq data (read-line ff)) ;;;注意是- 不是_ (setq mm (strlen data)) (setq k (+ k 1)) ) ;;;while结束 (close ff);;关闭文件 (setq pm (list am bm z)) ;;取得中心点 (command "donut" 0 (* (/ dima 1000) 2.2) pm "") ;;打印中心点 (princ "pmend") (princ k) (princ "= ") (princ pm) (setvar "osmode" os) ;;回原捕捉功能 ) ;;;取坐标子程序 (defun draw_wires() (setq x1 (atof (cadr ppp))) ;;;atof是字符串转换成实数,取得键合点坐标 (setq y1 (atof (caddr ppp))) (setq x2 (atof (nth 3 ppp))) (setq y2 (atof (nth 4 ppp))) (setq z 0) ) (defun getmn() ;;计算中心值坐标 (setq a1 x1) (if (> ax a1) (setq ax a1) ) (if (< an a1) (setq an a1) ) (setq am (/ (+ ax an) 2)) (setq b1 y1) (if (> bx y1) (setq bx b1) ) (if (< bn b1) (setq bn b1) ) (setq bm (/ (+ bx bn) 2)) (princ "\nax= ") (princ ax) (princ "\nan= ") (princ an) (princ "\nbx= ") (princ bx) (princ "\nbn= ") (princ bn) ) |
