查看: 1506|回复: 2
高手来帮帮我
发表于 2003-5-14 10:31:00 | 显示全部楼层 |阅读模式
我的CAD2002突然不能用了,说是程序有问题,我看了显示的内容如下:
ACAD 在 017f:65fe1e3b 的模块
AC1ST15.DLL 中导致无效页错误。
Registers:
EAX=00000000 CS=017f EIP=65fe1e3b EFLGS=00010246
EBX=bff77796 SS=0187 ESP=00e4f888 EBP=00e4fa54
ECX=00000000 DS=0187 ESI=00f706a0 FS=119f
EDX=bff7024c ES=0187 EDI=00000001 GS=0000
Bytes at CS:EIP:
8b 10 8d 4e 04 8d 7e 14 89 11 8b 50 04 89 51 04
Stack dump:
00000001 00f70e60 00f70770 64616f4c 7262694c 41797261 00480000 00480048 00480048 00480048 00000048 03020120 07060504 0b0a0908 0f0e0d0c 13121110
我不知道是什么意思,求求又没有人能够来帮帮那个我
怎么恢复我的CAD
我已经重装了我的CAD了,可是还是不行,我都装了好几遍了
 楼主| 发表于 2003-5-14 15:55:00 | 显示全部楼层
怎么没有人呢回复我
是不是搞不定啊
发表于 2003-5-14 22:35:00 | 显示全部楼层
you can try like this
first, install autocad2002; if it doesn't work, then uninstall it and restart your PC, install autocad2002 again. sometimes it does work.
you also can try another version, such as english version. and now nearly 20 computers i installed autocad2002 english version. it works very well. the chinese version sometimes doesn't work, just like your problem.
GMT+8, 2025-5-10 20:16 , Processed in 0.159797 second(s), 23 queries , Gzip On.
